hi guys:
i need your help very badly. my ride is a 95 lancer. and, my problem is: the door panel -- fabric part just peeled off completely. any suggestions on how will i replace it?
thanks in advance.
hi guys:
thanks in advance.
any competent car upholstery shop can repair or replace it. It also an opportunity to change all four panels to a new cover.![]()
conz, sakit ng mga lancers yan. in fact yung sa Pizza ko is starting off, pero naunahan ko na lang idikit ulit.
gh is right. any car upholstery shop can repair or replace that.
Just take it to any upholstery shop, they can easily stick it back using rugby.
i-DIY na yan kung aayusin lang....kung papalitan, have upholstery shops do that, i highly recommend seatmate..
thank you guys, for all the inputs. i appreciate it very much.MABUHAY KAYO!!
san po ba malapit yang seatmate exact address po sana.may nakakaalam po ba sa inyo ng PORTILLO's upholstery shop buhay pa po ba yun
Rugby contact cement ang ginamit ko diyan. Nilagay ko sa tongue depressor.
Apply cement on both door and on the back of the cloth. Let cure for around 30 mins. Then stick cloth to door.
Seatmate's really good. Just had my sidings done also (Lancer Pizza Pie). Light gray leather.![]()
makikisakay na rin po sa thread na ito. naglalagay din ba sila nung sa floor ng matt pati nung sa trunk? how much po kaya?
Yung sa E36 316i ng pinsan ko nabakbak din. Pina-leatherette na lang niya sa Coventry. Alam ko mura lang for all four doors.
Dali lang yan palitan. Kahit ikaw DIY nalng tapos post mo dito.
Buti nga simple lang prob nyo.. ESi ko basag yung center (plastic or fg ata) part ng door sidings/door panels (as per Honda ang tawag daw dun "door lining assembly).
