Results 11 to 19 of 19
October 13th, 2014 04:33 PM #11
- 52,697
October 13th, 2014 04:55 PM #12if your car is one of those with thick butyl adhesive between the windshield glass and the metal frame...
if you can remove the borloloy weatherstrip, you might be able to visualize the area where the thick butyl adhesive has separated from the glass/metal.
October 13th, 2014 09:00 PM #13
October 13th, 2014 09:16 PM #14
Check for rust in the uuper part of the windshield where it is installed
October 13th, 2014 10:22 PM #15
^No rust on that part. It's really weird, it leaks on one place only.
October 13th, 2014 10:36 PM #16
mentioned earlier, when the car (specially unitized body) is raised at one corner with a garage jack higher than the scissors jack that came with the car, the body flexes too much and the windshield either cracks or the adhesive butyl tape peels of or creates a gap either between the butyl and the windshield or between the butyl and the body of the car. perform an inexpensive test using a stethoscope and compressed air. have an assistant blow compressed air in front of the windshield while you on the backside (inside the car) listen with a stethoscope. this way, you and pinpoint the leak to within the closest 1/2 inch from the suspected leak
October 14th, 2014 12:18 AM #17
- 52,697
- Jan 2013
- 143
October 30th, 2014 06:38 PM #19nangyari na sakin to, roof leak sa may same area, turns out, may rust na under the paint kung saan nakadikit yung weatherproofing.
Suzuki JIMNY [merged threads]
