Results 31 to 40 of 58
- 82
December 28th, 2002 01:20 PM #31acoustifoam are usually available in stores like HANDYMAN (robinsons) and TrueVAlue Shops. They are distributed by HAN GANG.
- 82
December 28th, 2002 01:26 PM #32cliff, hehehehe i knew it would put a smile in your face. i also did put lots of acoustifoam in my trunk flooring and it also made a good insulation as well. i also plan to put some more inside the wheel wells kaya lang la pa ko time. i also put a 5mm layer of acoustifoam in between the roof and the ceiling??? (di naman sidings un di ba) and it significantly lessened the heat i feel especially when driving in the mid afternoons. dati kasi pag nag park ka sa tanghali, kahit bukas na aircon eh ramdam pa din yung heat from the roof. ngayon wala na. heheheh
- 237
December 28th, 2002 01:46 PM #33guys
i using toyo prxes t1s tires....
pag nasa highway ako (macapagal road) tapos bukas bintana rinig na rining ko ung ingay ng tires....
maingay ba tlga ung toyo tires?
bago pa kasi so baka hindi muna ako magpalit....tska ung isang tires e napa vulcanize ko na dahil na tusukan ng pako tapos napadaan sa lubak na natakpan ng tubig...bad trip tlga....sayyang nga eh...
- 82
December 30th, 2002 11:14 AM #34meleagant8, yes maingay nga din yung mga toyo tires. yun sakin dati pag dumaan ako sa SSHW at bukas bintana, dinig na dinig ko yung WUNGWUNGWUNGWUNG na tunog sa kalye.
- 237
December 30th, 2002 10:12 PM #35yep...nagets nyo!
so malamang, the solution would be changing of tires?
kung un lang...malamang nito....hintay pa ko ng few years....ilan po ba life span ng toyo proxes t1s?
- 82
December 31st, 2002 12:02 AM #36depende yan kung gaano ka kadalas magbyahe at pano ka magdrive ng oto mo. pag hataw -brake, hataw-brake ka.... sandali lang yan. 1 year tops kalbo na yan hehehehe.:wink:
- 237
December 31st, 2002 01:18 AM #37naku di naman po ako ganun magdrive....hehehe....most probably..ano po ung range ng life span ng tires?
- 130
January 8th, 2003 09:51 AM #38happy new year pipol!!
Just finished installing acoustifoam on my cars trunk.. tama ka sir juno, laki ng nabawas sa road noise coming from the back. meron palang acoustifoam na may adhesive na, yung wala ng kasamang dalawang latang rugby (mas mahal nga lang ng 100). pero less hassle tsaka mas malinis ang trabaho.. again, problem ko na lang ngayon ay mas nagiging noticable na yung little katoks coming from the dashboard dahil tahimik na nga yung ride (siguro mga maluwag na connections lang)..
meleagant8, depende siguro kung how often you use your car and how you drive it, on my experience kasi, mga 3 years ang tinagal ng tires ko dati.
- 237
January 8th, 2003 08:09 PM #39bad trip nga....putcha, ang dalas ko madisgrasya sa mga pako, turnilyo etc....
ngayon lang, merong mahabang pako na punasok sa gulong ko...lumabas sa sidewall...sana di tinamaan sa loob....
uy cliffjumper, naka sounds set up ka na ba?dapat ba naka sounds set up bago maglagay ng mga acoustiofoam?
January 8th, 2003 08:12 PM #40
ubod ng ingay ang NCT3... as in sobra... para kang naka tube na gulong na malaki... bad trip...
change your tires... also, while waiting for your current set to wear out... always check the tire pressure... laking ingay kung mali pressure mo.
don't know why local goodyears suck so much...
Yaris Cross: ₱ 200,000 for S HEV Zenix: ₱ 150,000 for 2.0 Q HEV CVT
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
