My sister's car (Lancer, itlog - EL) was kept in the garage for nearly a month. Yesterday, I went to their house to start the car (gagamitin ko sana today). Nag-start naman sya agad (one click nga lang eh) kaso after a few seconds (3-5), namatay. So, I checked the battery (oks naman) then the gas in the tank (more than half). Then I started the car ulit. Same result. After a few seconds namatay.
Pinasalubungan ko ng kaunting gas yung carb. Start ulit. Ganun din, after a few seconds namatay (3-5 seconds pa din). Start ulit. This time, I gently stepped on the gas pagka-start. Unfortunately, ganun pa din. Kahit i-rebolusyon ko yung makina or I put pressure on the gas pedal, after a few seconds eh namamatay. The engine revs up and just goes dead.
I'm no expert sa tsikot so I'm asking for your advice. What could be the possible cause (or causes) of this problem? Sa limited knowledge ko sa engines, I only have three guesses:
(a) Yung fuel pump (kaso parang hindi kasi I removed the fuel filter, emptied it's contents, then placed it back. Pagtapos mamatay nung engine, I checked it eh may laman.
(b) Yung carb - baka kailngan ng palinis or i-calibrate.
(c) Nahaluan ng tubig yung gas tank (I was thinking na baka last time sila nagpa-gas, nahaluan ng water yung gasoline).
What'd ya think mga fafa at mamah?
TIA!!!!!
Alternator doesn't seem to hold up... but that's just a guess, since you already singled out fuel, and battery... have you also checked the oil and water levels?
