Results 11 to 18 of 18
January 4th, 2008 01:17 AM #11
mga masters,
ganitong ganiton ang problem ko for 6 years sa mazda 323 1996 ko,
kanina nag palit nako ng release bearing, clutch disc, pressure plate, pilot bearing, oil seal, at ganun padin nandun padin ang maingay na kumakaskas, nawawala lang sya if press down or apakan ko ang clutch
panu kaya maayos to? gumanda hatak ng auto kaso nandun padin ang maingay na kaskas ng bakal
sino magaling sa transmission...sana maayos nato at mapakita sakin kung anu yung sira..
willing to pay po ako
0917-470-3846
joms - forcemajeure
January 4th, 2008 10:11 AM #12
hey bro, have your Transmission Input Shaft inspected. since na posibleng nag wear out na yun and is causing that whining or chattering sound. kaso nga lang, you have to take off the tranny again so that youll be able to inspect it. also, did you already "break-in" the clutch??
aite, peace.
January 5th, 2008 01:57 AM #13
diko sure if tiningnan nila ang transmission input shaft, tnx sa reply...
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Aug 2007
- 11
January 8th, 2008 11:30 AM #15
January 9th, 2008 01:22 AM #16
*stitches and burn
mga peeps nasagot kona ang problema ko, internet lang pla katapat nito
eto nakita ko with my research
http://auto.howstuffworks.com/clutch2.htm
[SIZE=+1]Clutch Diagnostic Test[/SIZE][SIZE=-1]If you find that your clutch has failed, here is an at-home diagnostic test that anyone can perform:[/SIZE]- [SIZE=2]Start your car, set the parking break, and put the car in neutral. [/SIZE]
- [SIZE=2]With your car idling, listen for a growling noise without pushing the clutch in. If you hear something, it's most likely a problem with the transmission. If you don't hear a noise, proceed to step three.[/SIZE]
- [SIZE=2]With the car still in neutral, begin to push the clutch and listen for noise. If you hear a chirping noise as you press, it's most likely the clutch release, or throw-out bearing. If you don't hear a noise, proceed to step four.[/SIZE]
- [SIZE=2]Push the clutch all the way to the floor. If you hear a squealing noise, it's probably the pilot bearing or bushing.[/SIZE]
[/SIZE]
[SIZE=2]
ANG PROBLEM NALANG EH SINONG MEKANIKO ANG MAY ALAM NITO? hihihihi[/SIZE]
February 5th, 2008 09:09 PM #17
mga peeps,
eto na naman ako nagpapalit nko ng tranny sa mazda gen1 ko
June 3rd, 2009 12:11 PM #18
almost 7 years ko na tinitiis ang ganitong problem sa tranny, everytime na cold na ang engine, pag start mo at naka neutral, 1st and 2nd gear ka may maingay na kaskas ng
bakal sa tranny, nag palit nako ng clutch disc, pressure plate, pivot bearing, release bearing, clutch fork at pati buong tranny, ganun padin..nawawala lang ang ingay if you make
tapak on the clutch,and pag mainit na ang engine...
dahil sa wala akong magawa at puro internet nag try lang ako sa YOUTUBE search ako ng noise on tranny may lumabas at same problem kame, everytime na apakan nya clutch
nawawala daw... ang kaskas ng bakal.. ang solusyon nya eh naglagay sya ng synthetic oil sa tranny nya Lucas Synthetic Treatment...wla naman brand d2 na ganun eto po yung link sa youtube
[ame="http://www.youtube.com/watch?v=JE3rmcNbWWc"]YouTube - NVG T850 Noise[/ame]
wla naman ganyan brand d2 so nag decide nalang ako na top 1 made in usa 3 liters synthetic oil na pang engine ang lagay ko... (may isa pa naman akong tranny if masira wag naman sana) yung top 1 P280 each plus P50 labor, pag alis ko sa shop, may ingay padin pro nawala ng konti..so sad padin ako...sabi ko pag gising ko bukas..dun ko malalaman...
pag start ko nung umaga kalako antok lng or tulog pako aba nawala ang ingay...na miss ko sya promise...ahihihi nawala ang ingay...kaso late na nung malaman ko solusyon
gumastos nako ng magkano kaasar... sa bagay decision ko naman lahat ng gastos na ginawa ko... sana wag naman masira tranny ko dahil sa experimento ko..
anu po masasabi nyo mga fafas? may isang tranny pa naman ako kaya malakas loob ko...pro so far 1wk na eh ok naman takbo ko... diko po kayo encourage na gawin to gusto ko lng share kasi natuwa ako sana tama ginawa ko...
Without more context like when was the last time these items were serviced/replaced, it's hard to...
