mga bro, ok lang ba umikot agad ang fan sa may radiator kahit naka-on pa lang ung susi, di pa man kac ako nag-start ng engine umiikot na yung fan, kahit sa umaga. Thanks!!!
yung sa lancer ko ganyan.. ganun na sya since pag labas ng casa.
etong sentra ko hindi sya ganyan.
i guess it depends on the car.
Dati hindi ganun, nagsimula yun ng magpapalit ako ng rear shock absorber tapos nakita nung engine support na sira na kaya pinalitan, after nun ganun na nga on pa lang ikot na agad ang fan ng radiator.
Dati ganun pag nag-on na ko ng a/c ikot na din pero ngayon nauuna pa sa a/c, san kaya mga bro problem nun para pag nagpaayos ako ma-identify ko yung talagang gagawin ng mekaniko, corolla '97 big body nga pala ride ko, thanks!
ganyan din sa akin, pagswitch mo ng on umiikot na agad radiator fan, i have mazda 323 '97. i think depende talaga sa settings yan sa casa and sa car din. yung sa bayaw ko nmn 98 mazda 323 din pero hindi umiikot yung radiator fan pag switch mo ng on.
Thermo fans run on a temperature sensor normally located in the coolant piping somewhere. If the sensor is faulty the fans will come on when the ignition is on. The fans will also consume power from the engine all the time making it less fuel efficient.
If the car overheats at speed, the problem is either a dirty/clogged coolant system or the radiator is incapable of handling the cooling (too small).
Or.
If ignition is on fan will come's on when the system is in the defrost position (on not off position), the AC compressor runs to help dehumidify the air being blown on the windscreen to more quicly clear any mist. Whenever the AC compressor runs, the condenser fan (and somethings the regular cooling fan as well) will turn on to maintain airflow over the condenser.
