Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
    Jun 2005
    #21
    when u say "umuuga" ano meaning mo? yung tipo ba na pag-apak mo sa pedal eh parang nagaalangan yung engine bago humataw (hesitation)?
    kung ganun nga ang nangyayari, it is caused by a vacuum leak. may sira ang carb ang has to be repaired. as for my case, plunger ang sira.
    as for katok, u can either change to higher octane gas or have ur timing retarded para hindi tomope. not sure kung valve tappet adjustment ang makakatanggal ng tope pero im quite sure na sa timing aayos yan. (based on experience). yung valve tappets, kapag kailangan ng adjustment, maririnig mo kasi maingay yung engine. mas maingay than usual kahit naka-idle lang.
    Quote Originally Posted by aann
    thanks for the reply sir...
    question...ginagawa ba ito kapag ngpa tune-up?...pina tune-up kasi yng ktse kahapon pero d ako nagdala...
    FYI, i am asking these questions kasi nraramdaman ko pag nag-accelerate ako d smooth...around 20-40kph parang "umuuga" (maling term ata) or parang may konting pigil sa pgka accelerate....
    and then also, pag i-try ihataw, i.e. from 1st gear, accelerate then change pagka around 3-4k change gear sby bitaw clutch...may konting katok or tope...whichever it is...
    i'm not usre kung tune-up lang ba...kng air filter cleaning...kng change gasoilne ba para mawala....
    icp ko rin bka gasoline ang cause, ksi nung bagong kuha ko ito from the prev owner, parang la nmn ako nraramdaman, or dko lang msydo npansin..not sure....ten one time, kinargahan ko ng unleaded ksi yun nmn daw knkrga ng prev owner...after nun nramdaman ko parang mdyo pigil yng accelerate pero d msydo...tpos nung ngpagas ako uli, XCS kinarga ko (d ako nag drain)...then after that, observ ko is parang lumala pa ata...
    d kya naapektuhan ang engine because of this? or tuneup and d proper fuel will fix this na?
    TIA!!!
    Sep 2004
    #22
    Quote Originally Posted by sirkosero
    yes parang ganito nga..kaso konti lang and mostly this happens pag mabagal, around 10-40kph....pano ko ipapa-check if may sira nga ang carb?..kelangan bang buksan ito para makita?...delicate na ba yng bubuksan lang ang carb to check?
    thanks for replying!
    Sep 2004
    #23
    also, san pwde ipa-check ang carb?...and just in case na kelangan ayusin, mga magkano kaya?
    thanks again?
    Jun 2005
    #24
    kapag DIY ang gawa mo sa carb, medyo mahirap kasi more of trial and error lalo na sa float adjustment. better let professionals do it for you. yung vacuum leak naman, kasi sa case ko, yung plunger, may parang bearing enclosed sa piece of rubber. dun sa rubber may punit na. pati yung nag-ssquirt ng fuel barado kaya kinailangan ko ipagawa. sa kamuning madami gumagawa dun. sa m2m ako nagpagawa kasi dun, makikita mo talaga na kinakalas carb mo at alam mo inaayos. sa iba kasi, di nila ipapakita na ginagawa carb. basta suggestion ko, pag ipabubukas mo, use a repair kit. mura lang yun. around 300-400 pesos. wag ka papayag na linis-linis lang at walang papalitan na piyesa. ganun nangyari sa akin kaya lalo nasira sasakyan ko eh. wag ka din paayos sa evangelista. isa lang shop ng carb dito at mahal pa maningil.
    sa m2m, ang ginastos ko 350 sa labor. tapos punta ako sa malapit na autosupply at bumili ako carb repair kit. worth 350 pesos ata. basta less than 800 nagastos ko sa lahat. yung gumawa ng carb ko sa m2m, yung bata. pero magaling naman gumawa. basta palitan mo lahat ng kasama sa carb kit. kung gusto mo din matipid, paliitan mo yung primary jet ng carb.
    btw, kapag magpatingin ka sa kamuning, never hastily trust any shop. always ask for a second or third opinio from other shops. kung ano yung common na diagnosed na sira, most probably ito nga talaga ang sira. hth.
    Sep 2004
    #25
    thanks for the prompt reply! appreciate it!
    overhaul na ba ang tawag sa ganyang work or iba pa ba yun?
    also, yng kit po na snsbi mo, iba-ibang brand pa ba ito? ano ang magandang kit?
    pasensya sa daming tanong...thanks!
    Jun 2005
    #26
    pag bubuksan ang carb overhaul na tawag dito. pero try mo muna gamitan ng carb cleaner na nabibili sa hardware. baka sakali maayos dun. iba-iba ang brand ng carb repair kit. basta bili ka lang ng galing japan. ang akin, keyster brand kasi yun lang nakita ko eh. so far, ayos naman. may iba naman sabi meron daw seikin na brand.
    Sep 2004
    #27
    salamt uli sir sirkosero!
    Jan 2003
    #28
    about the carb repair kit, wala ba available nito sa M2m mismo? para di na ko hanap.
    if not saan ka bumili? sa kamuning din ba?
    iba iba ba ang carb repair kits for different brand of cars?
    Jun 2005
    #29
    Quote Originally Posted by buknoy2002
    alam ko wala silang stock ng repair kit. magpapabili ka pa pero cyempre may patong na sila na 100-200 kaya i opted to exercise my feet yung autosupply medyo may kalayuan din. ma 10 min. walk din. katabi mismo ito ng a&m. pwede ka magpabili sa kanila kung ayaw mo maglakad.
    yup. iba-iba ang carb repair kit para sa iba'tiband kotse. kung bibili ka, magdala ka ng sample. atleast sample lang ng gasket sa float pwede na.
    Jul 2003
    #30
    magkano brand new carb??? yung surplus???
    san ba magandang bumili ng carb???
    corolla gl 4AF (aisan ata yung carb nito)
    tnx!!!
questions on carb overhaul
