Results 31 to 40 of 44
January 22nd, 2008 08:48 AM #31
Sir Rion,
OT: Taga aha ka? :hihihi: May Liteace ka rin ba?iam3739.com
January 22nd, 2008 01:32 PM #32
chekreet na lang po kung taga-saan ako.
May jdm townace yung papa ko, 2wd, 3c-t w/ intercooler + projector foglamps. Yung bro ko may jdm townace 4wd 2c-t. both 5-doors.
January 22nd, 2008 02:22 PM #33
Gud day again mga sirs.
Uhm sir drey, what i meant by 1:11 ratio was for my 5k engine with the said components installed. and did my own adjustments to the carb and distributor. and super tipid driving 1800rpm tach reading 60kph max.
and sir rion, sa underside ng 2nd row seats just right after the airbox compartment there is a space there for an IC but you have to fabricate your own mountings and bend your own tubings. Got my IC pala from surplus IC ng Isuszu Trooper. and ang liteace ko ay local pala.
Thanx for welcoming me here in tsikot.
January 22nd, 2008 03:19 PM #34
same here, my intercooler came from 4d56 pajero.
but mine is terrible... before the boost picks up, the meter goes -1psi... a little unresponsive compared to not having a IC. but the mid and high bands are really good. kaya mas prefer ko myroon ic.
how about yours?
January 22nd, 2008 08:43 PM #35
Sir,
11 km/l in the city for a 5K? How did you do it? Share naman po kayo ng sekreto nyo... Please. :please:iam3739.com
January 23rd, 2008 11:19 AM #36
Sir Drey
there is no secret just plain safe & smooth driving plus TLC sa sasakyan.
But one thing if you would really like to know how I did it "lean burn" some may say unsafe they're correct but if adjusted properly you could save on fuel. what I did is change my carb jets from 150-primary 120-secondary to smaller ones 120-primary 106-secondary. And add khaos as to avoid pumping losses during close throttle operation, also use thinner oil shell helix 10w-40. Advance Timing 10deg. BTDC. Installed 4-2-1 headers and larger diameter exhaust and larger muffler. aircon thermostat setting 3 dot. and use 70%-30% prestone coolant and distilled water to solve overheating problems but don't take out the thermostat. And use a nice fuel for me caltex vortex silver. ANd always check your brakes and adjust if needed. change gear oil tranny and diffs. to omega gear oils.
Sir rion
If I may ask which diesel fuel brand is best for you and what fuel brand are you using. and do you use additives? And what brand of boost/vaccum gauge did you buy and how much?
January 23rd, 2008 12:16 PM #37
Thanks sir... This is noted for application in the future. But I still have doubts on Khaos...
Btw, Change in Carb Jets? What is that sir? Is that a part you need to replace on the van? If not done correctly, what happens to the engine?iam3739.com
January 23rd, 2008 08:40 PM #38
I really don't drive it much, my folks pays for the gas most of the time and they go to any gas stations. but I remember Petron did better mileage, however, I cannot bet on it. baka kasi different circumstances and factors yun...
we don't use additives, we use autoguage 2"inch boost+vacuum guage. bought in banawe for 1K. In my town it costs 1.5K
do you use any form of boost controller and blow off valve?
January 24th, 2008 09:10 AM #39
*Sir Rion,
What are the benefit of these?
we use autoguage 2"inch boost+vacuum guage.Last edited by drey; January 24th, 2008 at 09:15 AM.
iam3739.com
January 24th, 2008 10:25 AM #40
bro yung jets that im talking about are the ones inside your carburetor that controls the amount of fuel when you step on the accelerator pedal. this objects looks likes screw with a tiny hole in the middle. when you change this things your really doing an carburetor overhaul palinis mu na din ang entire carb while at it. And sir rion where did you install the gauge where did you get the readings from?
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
