Results 1 to 10 of 10
- 154
July 6th, 2009 10:19 AM #1Ginamit ko auto ko kahapon malakas ulan tska medyo matubig ang daan.
Pagkagamit ko kanina, napansin ko sa muffler ko may lumalabas na puting usok.. w/c is ngayon ko lang napansin na nagkaganon, dati hindi naman. ano kaya problem nun?
car ko pla is 1996 civic lxi..
help please...
July 6th, 2009 10:43 AM #2
baka moisture lang inside the engine.
if symptoms persist, consult your mechanic.
you might need a compression test later on.
- 154
July 6th, 2009 10:46 AM #3
July 6th, 2009 10:54 AM #4
White smoke is a sign of water in the combustion chamber. If you have white smoke on a dry day when the engine is warm, then it's a problem, because the water is probably coming from your headgasket.
If you have white smoke in the middle of a rainstorm and flood, where do you think the water is coming from?
July 6th, 2009 11:00 AM #5
Kung palaging may usok, then that's a problem.
Observe lang muna. Don't be praning.
- 154
July 6th, 2009 11:16 AM #7Kapag dry naman yung weather hindi umuusok ng puti, kapag rainy lang. hehe
Kaso hindi ba masisira kotse ko kung ganun usok kapag rainy? hindi ba mangangalawang yung loob?
Siguro nga moisture lang, kasi nagpuputi yung usok kapag nagmomoist din loob ng kotse bago gamitin.
July 6th, 2009 12:14 PM #8
^^^Based on what you said your car is normal, no need to worry about corrosion inside your muffler.
July 6th, 2009 06:34 PM #9
If it gets cold enough for moisture to condense inside your combustion chambers, the car won't run at all... that it runs at all means that condensation can't form, thus, rust won't be a problem. Don't worry about it. ;)
July 7th, 2009 12:48 PM #10
ok lang yan. pag uminit na yan mawawala na yun white smoke. pansinin mo yun movies pag ang scene eh nasa cold country yun mga cars may white smoke sa tailpipe.
Hello po, new lang po me sa Car Industry Me and my Dad purchased a 2nd hand po na toyota innova...
