Results 1 to 10 of 10
October 5th, 2003 08:44 AM #1
guys,
napapansin ko lang na pumapasok yung mga masamang amoy (canal) at usok (buses) sa loob ng lancer itlog ko.
yung aircon vents naman is switched to circulate inside the car. bakit kaya? what seems to be the problem?
sa rubber kaya sa gilid ng car pumapasok? sometimes kasi meron tulo na konti pag umuulan, front passenger window. or sa aircon dumadaan? yun bang switch ng aircon circulation e busted na?
kasi masama kay misis eh, ka-buwanan na nya and syempre pag nanganak na siya, baka makasama din sa baby namin.
October 5th, 2003 11:20 AM #2
malamang yung seal ng vent door ng aircon sira na. or yung vent door mismo sira. either naputol na yung plastic or yung spring.
try mo close-open yung a/c vent from recirculate and vent several times. dapat maririnig mo sya mag open at close. pag hindi baka stuck open yan.
October 5th, 2003 12:17 PM #3
yep done that open-close thingy, several times. there's a clicking sound din, you can here it close and open.
baka nga yung plastic/spring. ill need to have somebody check it. any recommended shops? makati area or i have to go to banaue?
October 8th, 2003 08:10 PM #6
Try also to check the foam pads in the AC system inside the dash... this was the culprit in our car before (kinain ng daga yung foam or something).
October 10th, 2003 09:57 PM #7
happened to me before, what my suking mekaniko did was to actually covered the a/c duct with rubber mat. Bale yung lever mo for fresh air to recirculate di na totally gumagana, lagi na lang shang naka circulate.
my 2 cents. . .
October 11th, 2003 10:34 PM #8
check mo din yung parang exhaust ng cabin, yung labasan ng hangin/pressure kapag nagsasara ng doors. usually nasa likod ito. minsan nasa tabi ng rear combi lights, or sa rear quarter window panel. baka lagi ng nakabukas. dapat pressure from inside lang ang makakapag bukas dito.
Signature
October 14th, 2003 01:41 AM #9
ganyan din dati sa akin, pumapasok amoy usok. what i did is put silicon sa vent para di na mabuksan permanently. mas maganda pa nga ito dahil di na nadudumihan ang evaporator mo. so far wala namang problema.
October 14th, 2003 01:32 PM #10
sealed the air vent permanently... ganyan din gawa nung aircon mechanic ko!
also tsek the rubber holes na pinapasukan ng mga wires and cables sa may firewall mo, baka nakatanggal ito or hindi maayos ang pakakasalpak!
pwede ring yung mga rubber ng doors and trunk mo cracked na or hindi naka align!
