Results 21 to 30 of 32
October 28th, 2005 02:30 AM #21
hmmm...thermostat is yung nagkakabit mula radiator hose to water pump right? yun po ba un? umiiral nanaman ang pagka noob ko eh...
- Oct 2004
- 89
October 29th, 2005 10:58 AM #23Originally Posted by jayelgee
- Oct 2005
- 110
October 30th, 2005 08:54 PM #24yup guys,sabi nga nung tech is bka may leak daw...alin ba dun ang pwedeng mag-leak?
October 30th, 2005 10:04 PM #25
honestly, for me gingoyo ka nung pinagtanungan mong yon....
1.)thermostat na tinutokoy ay hindi pwede at hindi kailan man pwede maging source ng leak.kasi, no gas na dumadaan dito at kung original pa theremostat mo makikita mo lang yang may rod na nakatusok sa evaporator mo at 2 wires...it acts a switch for the compressor kapag nareach na ung desired coldness ng evaporator...
2.)ang posible leaks lang commonly ay sa fittings, maaring may sirang o-rings or di maganda ang pagkakasalpak lang ng mga yun..
3.)ung pipe leaks mostly due to high pressure or too much bending of the pipes.
4.)evaporator only leaks kung nilinis gamit ay ung LYE, pero di masyadong binanlawan..ung natirang LYE will react on the water that the evaporator will produce and in turn mabababad sa evaporator which will eat out the evaporator's soft aluminum structure.
5.)baka due for replacement na ung expansion valve and "reciever-dryer", kasi in due time, nagbabara din ito because of dirt na nakapasok sa open pipes while servicing the aircon-system.ang masama nito, kapag pinabayaan mo, maaring cause ng pag-babara ng pipes which will make the compressor work much more that it need..
6.)compressor naman nasisira kapag napapabayaang madumi ung system, when releasing freon, di nirereplace ung oil na nawala, which may lead to pagkonti ng oil sa compressor...
halos lahat ng dapat maexperience sa aircon, naranasan ko na,e...un lang di ako kay mang mario nagpapagawa, dito ako sa may lampas pa ng tandang sora ave, along mindanao ave..tago ung lugar at talagang sadyain...si "mang ernie" naman ang pinupuntahan ko dun..
ngayon ung liteace ko naman...7500 ang quote sa akin dun used a slightly bigger nippon-denso compressor(di ko maalala ung model,e) na ipapalit(kasi dual aircon liteace ko+cold and hot box).. kasi ung compressor ko halos di na pala bumubomba, complete na din un job(freon, cleaning, flushing ng pipes,condenser and evaporators)..
kung may makakapag PM sa akin ung exact way papunta sa kanila, sadyain ko sila..dito lang naman ako sa proj. 6,e, 2nd expert opinion ika nga..(sorry sir key7wizard4 sa konting pag-sawsaw sa thread mo, ha?)
- Oct 2005
- 110
October 30th, 2005 11:20 PM #26Originally Posted by alwayz_yummy
October 31st, 2005 08:06 PM #27
welcome....salamat sa surplus ng japan na binaboy ang pag-convert....sa almost 17-year-old maxima, at eto ngayong ride ko...and a hefty amount of money kaya ako natuto ng ganito...
puntahan mo na din, at baka magkita din tayo dun kung sakali..
nga pala, kung light repairs sa a/c system ng rides ko, i DIY it...(makatipid ng sa labor and parts,e)
November 1st, 2005 09:58 AM #28
mahal aircon parts, in your case baka leaks lng sa tubes. they can always test the lines naman. kng thermostat daw ang problem then minor lng yan. it jst controls the temperature in the car. hindi nare-repair ang thermo, replace na talaga. pinakamahal parts ng aircon ang evaporator, condenser at compressor. evrything else medyo mura na.
November 1st, 2005 10:04 AM #29
umzzzzz: thermostat ng engine yun, same function with the aircon system's thermostat, regulate ng temperature
Tsikot Member Rank 4
- Oct 2004
- 2,315
November 2nd, 2005 10:27 PM #30ako nagbackjob ako after palinis aircon ko. May hinigpitan lang ata sa condenser. Sana hindi compressor yun may deprensya. I need to check pa ng ilan gamitan kung hindi sira ang compressor ko.
Ang tagal nga bago mapinpoint yun sira sumakit tuloy tiyan ko hehe
Monk-owned R53
