Results 1 to 13 of 13
    Sep 2005
    para san po ito at san pwede magpalagay??
    Please be more specific.
    If you mean the plastic underneath the interior door panel, it's a moisture barrier.
    You can buy plastic in rolls from bookstores and install them yourself.
    Aug 2006
    what's the adhesive they use for the barrier?
    I don't know what you call that adhesive. I just call it 'gummy'.
    But you don't really have to use that. For restorations, we just use whatever we can get our hands on. Even those 'liquid gasket' originally intended for engine rebuilding. As long as it will bond to the plastic and to the metal.
    Oct 2003
    yung iba ginagamitan ng stapler. i saw one sa banawe.
    Sep 2005
    Quote Originally Posted by wakin View Post
    alketran saw yun, hirap nga tanggalin..kelangan pa ng kerosene to remove completely...pano na stapler yung plastic sa metal???
    you can use dow corning "silastic" silicone sealant for that. 100 pesos isang tube but the gun costs around 400. if you don't want to buy a sealant gun then you can just push the bottom with a piece of wood. or buy the sealant in the "toothpaste" tube, mas mahal lang nga.
    Sep 2005
    Quote Originally Posted by Baron View Post
    yup! it's asphalt aka alketran.
    Bakit yun ang gamit nila? nde ba pwede ibang sticky compound? hehe hirap tangalin. badtrip.
    Yun ang ginagamit because it can be reattached afterwards and is temperature stable. Perfect for other markets na malaki ang temperature changes (e.g. Middle East).
    Sep 2005
    Quote Originally Posted by ineedmorehp View Post
    For several reasons:
    1. it's very sticky
    2. it's cheap
    3. it's water-resistant (yes it is)
    4. easily accessable and available.
    Jan 2008
    medyo matagal na ito pero tanong ko lang ulet kung saan nakakabili nyan sealant na pang door moisture barrier at anong kaya brand name?? thanks
    Jan 2010
    the adhesive that is black in color and remains tacky over time is called butyl tape- a product of minnesota mining and mamanufacturing corp (3M)
plastic sa door
