pano po ba lalambot ang windows ko?
sobrang tigas kasi ska masyadong mabigat.
madali po bang buksan ang pintuan?
hatchback po ang kotse ko
your window mechanism simply needs cleaning and greasing. if you plan to DIY and not familiar on how to detach the door sidings, better have it serviced na lang. there are lots of people who just know how to do that. just visit banawe and any shop could do the job for you. madali lang buksan yang sidings ng door panel if you know where the clips and screws are mounted.
The reason why windows become hard to pull up and down is rusting and dirt accumulated in the window riser / mechanism.
keep a WD40 or similar lubricant handy. once you have opened your door panel, you might as well apply lubricants to the joints of your door lock mechanisms as well.
baka maasar sir, basagin pa windows, hehehe :DOriginally Posted by fierari
kidding aside, madali lang sir, nagawa ko na rin yan pati yung pagpalit ng solex locks. matagal nga lang at madumi sa kamay pero enjoy naman. i suggest try mo sa isang door pag di kaya, pagawa mo na lang sa iba.
[b]7drummer[/7]::: by nature po matigas ang bintana nyan :D Better use it more often or have the mechanism greased as suggested by the others. or for 8000thousand give or take, you can upgrade to power windows. Dati may nag-aalok sakin. For this amount, kasama na motors, sidings switches etc. Hope this helps
nsa magkano po ba magpa power windows? advenure kc amin.. pawis windows....
may iba iba bang brand ng power windws??
