Results 21 to 26 of 26
- May 2004
- 66
August 1st, 2004 10:12 PM #22
i duno if tama ako but... if redline ka lagi magdrive go for 4-1... if mababa lagi rpm mo drive go for 4-2-1... for daily driving... 4-2-1 will be better... may lakas sya kahit sa low rpm... while yung 4-1 and lakas nya.. todo nasa higher rpms po...
btw.. bago ka bili.. hanap ka narin ng headers wrap... suggestion lang.. it will help u alot.. believe me... sobra init walang wrap... i remember... nauubos tubig ko lagi sa radiator... then... i decided to have a wrap.. but ipon pa muna ako nuon uli.. hehe goodluck po
- May 2004
- 66
August 1st, 2004 11:09 PM #24
try auditioning na lang.haha. parang audio.. pakingan mo kung type mo..
August 2nd, 2004 04:53 PM #25
Mahirap yata yang naisip mong tip odell. Una, bihira ang may different muff setup sa same engine and model. Baka nga dito sa mga tsikoteers di pa mahanap yung same engine with different muff setup.
- Aug 2004
- 20
August 4th, 2004 03:59 PM #26am new here... heres what all about headers and cold air intake system
headers improves the engines exhaust system. takes away excessive backpressure. the 4-2-1 system is the best set up but check the diameter of the pipe to big of a pipe u will lose torque.
about cold air intake... it improves the delivery of air going to the engine. the colder the air goin to the engine the better to prevent pre ignition when it mixes with fuel.
if ur planning to buy be sure to match the diameter of your throttle plate and cold air intake system if not sayang lang pera.
Monk-owned R53
