Results 21 to 26 of 26
April 14th, 2007 12:09 PM #21
clutch?
sama ko na rin tanong ko.
kapag naka aircon ako parang nag sslide yung oto ko
pero kapag ndi naka aircon, ok na naman pero around 3k-4k ko feel yung hatak.
April 14th, 2007 12:25 PM #22
How old your clutch lining and pressure plate? Mararamdaman mo naman yan kung mataas na yung rpm mo tapos ayaw pa rin bumatak sliding clutch na nga pero kung ayaw lang bumatak at hindi mo napapagallit ang makina ng oto mo complete tune-up lang. I had experienced it before changed lang ako ng spark plug at konting re-gap lang ok n uli.
April 17th, 2007 11:13 AM #23
Hi newbie here, why not bring your car to the shop for another opinion? If you happen to passby QC area, why not drop by D2H Autoworkz and look for Danny Hipolito. Maybe he can have a look at it again before you buy another ECU. You can call the shop at Tel. 4159003. Try it bro.. Salamat
April 19th, 2007 12:42 AM #24
true...this normally happens sa mga corolla with almost worn out belts, ang resulta nagbabago-bago ang timing. my other suspected problem is your valves. singaw barbula.. oil gets into your valve chamber. minsan this happens pero di umuusok. it definitely causes power loss, and sometimes hard starts. since your car is a corolla, you might want to check and ask for help at grupotoyota.com.ph forums. There you can get good advice regarding your car problems and they will guide you on where you could take your car to be fixed through their shared experiences. Goodluck!
April 19th, 2007 06:23 AM #25
sori kung ot pero parang related sa topic. pa-change oil ako kahapon kasama palit spark plugs, nung tinanggal yung HT wires sa #1 and #2 may nakitang oils. possible po ba na head gasket ito? sabi kasi nung mechanic rubber/oil seals ng spark plugs lang papalitan. help naman po. tia
April 19th, 2007 08:17 AM #26
Latest mileage:
