Results 1 to 10 of 10
    Jul 2003
    sa mga nakapagpasadya na sa Caloocan Oil Seal, advice naman kung paano pasadya ng oil seal sa kanila.
    pinaayos ko yung steering gearbox ko using a repair kit (o-rings and oil seal) pero may leak pa din dun sa passenger side. pero dun sa driver side wala na. makinis pa naman yung steering rack so baka ndi kinaya nung oil seal na asama sa repair kit.
    papakabitan ko muna ng surplus na steering gearbox yung kotse. isasalpak n lang pero gusto ko pa din ayusin yung luma just in case may mangailangan ng steering gearbox assembly.
    ang kotse is civic esi 93.
    anu ano ba kailangan para magpasadya ng oil seal? nasa akin naman yung sample.
    kaya kaya ng half day kasi galing pa ako laguna. mas ok nga kung meron na sila stock tapos bilihin na lang sa kanila. pwede ba yun?
    thanks!
    Jul 2003
    called them a while ago. mejo mahal din pala tapos kelangan ng sample. 1 week pa bago makuha.
    meron kaya nagtitinda ng oil seal lang? i bought the repair kit from carpower in pasay. everything is ok except the one leaking in the passenger side.
    Feb 2007
    Hi fourtheboys, It means yung rack and pinion mo sa side ng passenger is mas malaki na yung butas kaya di na fit yung oil seal. Marami ka mabibili na oil seal and makakahanap ka nung size na kailangn mo. But the problem is hindi pressurize yung mga oil seal na yun, It can't withstand the pressure on the rack and pinion.Meaning to say its not an oil seal intended for power steering, kaya pag kinabit mo ala pa 1 week sometimes tulo agad steering fluid. Nangyari na sa Caravelle ko yan and kay COSCO (Caloocan Oil Seal Corp) ako nagpagawa nung oil seal. Solve problem ng power steering ko.
    Jul 2003
    mr jcastillo, ur right. ordinary oil seals won't withstand the pressurezed environment of the power steering gearbox. pero yung pinampalit namin is from the repair kit. i am not sure kung maliit na nga yung part ng steering rack sa passenger side. visual inspection does not indicate any damage such as scoring, scratches etc.
    anyway, magkano pala kuha mo ng oil seal sa COSCO? sabi kasi sa akin minimum daw ng 4 pcs tapos Php700 each. mejo stiff ang presyo. will call them again baka kasi meron sila ready made na na pwede isa or 2 lang muna.
    Feb 2007
    Yeah, minimum of 4pcs talaga sila. Kaya yung sa caravelle ko may 2 pa natira. Mas mahal quote sa akin dahil nabanggit ko na pang Volkswagen!!! . Parang 800 nga isa charge niya sa akin last year. Pero sulit yung oil seal. Maganda pagkagawa and iba talaga yung materials na rubber na ginamit. Tingin ko nga parang mas matibay pa itsura dun sa orig na Oil seal na Made in Germany na pinalitan ko. Tawad ka na lang sabihin mo 600 each, pag pumayag largahan mo na. Kesa bumili ka ng assembly na rack and pinion mas mahal.
    Jul 2003
    parang mas ok kung oil seals na lang yung pinalitan ko at ndi yung lahat ng o-ring na nasa repair kit. hehehehe
    will think about it. ok na kasi lahat except yung part na yun na may leak. and plano ng mekaniko is ndi na niya ibaba yung buong assembly. yung cylinder na lang since accessible naman siya.
    baka meron dito sa tsikot gusto ng 2 oil seal for power steering :D hati hati na lang hehehe
    Aug 2005
    ng advce ako s kbilang thread mo e tapos n pla hehehe, dmo kylangan mgpsadya n nyan mron n nyan dun tyaga ka lang mgikot. 2years ago ako ngplit nyan ung apat 3 o 4 n oilseal oring nga pla ung isa, dfrent store ko nkuha syempre kung san mura hehehe mdyo hrap lng hnapin pero mron.
    bka kya bmgay kagad hnd hydraulic type ung oil seal...bka lng...
    Jul 2003
    joey, tnx for the advice.
    anyway, would you mind if in your next post you type the words in full and correct spelling. parang text message kasi. mejo mahirap basahin. libre naman magpost dito at walang limit ang characters.
    any advice or suggestions about our car problems are welcome at mas maganda kung klaro yung pagkakasulat. peace!
    Aug 2010
    Quote Originally Posted by jcastillo932 View Post
    Sir How to contact COSCO, I need AXLE oil seal e, may tagas kasi ung transmission ng caravelle ko..
    Jul 2003
    Quote Originally Posted by shojienel View Post
    search mo lang sa internet yung number nila.
    btw, hindi ako nagpagawa sa kanila kasi 4 pcs ata yung minimum eh 2 lang kelangan ko. sayang yung 2 kasi hindi naman siya yung tipong papalitan agad. bumili na lang ako ng orig repair kit sa pasay. ok naman yung oil seal hanggang ngayon. nagka-leak ng konti pero hindi dun sa oil seals kundi sa gasket ng valve body so binaba ko DIY then nilagyan ko ng sealant. ngayon oks na oks pa din. walang tagas.
    pwede mo din i-try yung mga orig oil seals kung makakahanap ka ng match sa modelo ng sasakyan mo.
Paano magpasadya sa Caloocan Oil Seal Corporation?
