Results 21 to 30 of 33
June 27th, 2005 10:52 AM #21
btw, (ot) how long should the break-in period be on a newly overhauled engine?
June 27th, 2005 07:40 PM #22
AFAIK, you should be gentle on it all the way to the next oil change.
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 28th, 2005 11:19 AM #23Originally Posted by theveed
- Jun 2005
- 113
June 28th, 2005 02:04 PM #24Originally Posted by speedyfix
I once helped out a friend who had his Toyota engine sieze on him at 50 kph. The engine ran out of oil because it had a leak and the owner somehow forgot his morning routine of pouring in a quart of oil. Good thing he was quick enough to punch the clutch in, allowing him to regain control of the vehicle.
Well, to make an already long story short, I took out the sump, sprayed some WD-40 on to the crankshaft and underneath the pistons. I also took out the sparkplugs and sprayed some (not too much) into the cylinders. A few cranks and the engine started right up. (The engine previously would not budge, even when push started in first gear.) If he hadn't only broke a conrod, he would have been able to drive the car much longer before he finally had to switch to a newer one.
- Apr 2005
- 58
June 28th, 2005 03:25 PM #25Speedyfix & Shadetree -> are you guys sure? i mean, possible ba ang sinabi nyo about casa?
June 28th, 2005 03:30 PM #26
Our club's trusted mechanic used to be a supervisor at the casa. Since overhauls take a long time especially because it entails a lot of cleaning the casa more often than not assigns overhauls to cheaper OJTs. Since you cannot see your car being worked on how sure are you that they really replaced the parts they bill you for? There are also horror stories about some casa mechanics swapping orig parts with replacement or surplus parts.
- Apr 2005
- 58
June 28th, 2005 03:47 PM #27seminaristakuno -> yah, you're right. i also heard bad stories about casa people. only now i heard that their ojt personnel might be the one who fixed my car. if ever man, sana na-overhauled tlga yung altis.
- Jun 2005
- 113
June 28th, 2005 05:59 PM #28Originally Posted by vilaern
A similar thing was experienced by yet another friend. He's a mechanic and was called upon to retrieve a Hilux with a seized rear diff. The diff had been leaking oil and had finally run out of lube after a year or so of neglect.
All he did was fill the diff up with gear oil, gave the pickup a bump backwards to unseize the gears, and drove it the whole 30 kms down to the shop.
Tsikot Member Rank 4
- Oct 2004
- 2,315
June 28th, 2005 11:23 PM #29i think natuyuan ng oil yan or something sa radiator kaya kuamtok yun makina para ioverhaul. Dapat regular PMS sa casa or kahit sa mekaniko lang regular checkup. Pwede nga simple DIY lang
- Nov 2003
- 3,849
June 29th, 2005 01:08 AM #30yup pretty sure. normally, casa employs mostly newly grad mechanics and only very few seasoned master mechanics.
problem is, when you see the volume of the traffic of casa, you wonder how the master mechanics can keep up with every little thing that the people under them do.
