Results 11 to 20 of 23
    Nov 2003
    if it aint busted don't try to fix it talaga. just keep on taking care of it.
    Sep 2006
    sakit yata ng filipino yan eh.hilig mag pa overhaul kahit di alam ang sira. Anyway i have a friend who has 300,000+ miles on his 90' accord no need for an overhaul,runs fine.He changed the oils religously.
    Apr 2005
    Quote Originally Posted by afrasay View Post
    may nabago ba sa performance nun na top-overhaul?
    Before ako nagpat-top overhaul, malakas umubos ng langis at nag-oo-verheat yn aking sasakyan, lalo na pag long drive sa speed na 100kph or above at kung paahon. Nawala ang mga ito pagka-top overhaul. Pinalitan din yn cylinder head gasket at mga defective na mga piston (?).
    guys, pa update lang ng thread. yung 95 safari (local) ko kasi lakas mabawasan ang oil, but no leaks naman (had all the gaskets/seals checked&replaced already). tapos medyo malakas na ngayon ang usok (black). does this mean i need to have it overhauled? how much would it cost? any reliable yet cheap qc shop you can recommend? TIA
    Wulf,
    I suggest a dry compression test then wet.
    How is the smell and color of your exhaust?
    Engine temp?
    smells burnt, actually. not too strong but enough to be noticed. had overheating problems a month ago which was solved by replacing the temp valve
    Wulf,
    Have you changed your oil since?
    yes sir, 2x(!) in the past 5mos. w/ 2 refills n between (used up a 1gallon for both). been using biodiesel also
    Compression test talaga ang kailangan.
    This way you can verify kung top overhaul or possibly dukot ang solusyon
    How is your turbo? Air filter?
    Oil can also be pumped through the shaft going to the intercooler and inside the combustion chamber.
    ah...wala pong turbo ang local version ng Patrol with a TD42 inline 6 diesel engine.
    wulf:::gaya ng mga sinabi nila pa compression test mo muna para sigurado ka.
    larry:::mukhang ikaw ang may nararamdaman na sakit :D teka...natuluyan na ata na overhaul yan diba? overheat ba kamo?
overhaul
