Results 11 to 20 of 23
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 8th, 2006 10:26 PM #11if it aint busted don't try to fix it talaga. just keep on taking care of it.
November 9th, 2006 08:28 AM #12
sakit yata ng filipino yan eh.hilig mag pa overhaul kahit di alam ang sira. Anyway i have a friend who has 300,000+ miles on his 90' accord no need for an overhaul,runs fine.He changed the oils religously.
- Apr 2005
- 99
November 9th, 2006 01:46 PM #13Before ako nagpat-top overhaul, malakas umubos ng langis at nag-oo-verheat yn aking sasakyan, lalo na pag long drive sa speed na 100kph or above at kung paahon. Nawala ang mga ito pagka-top overhaul. Pinalitan din yn cylinder head gasket at mga defective na mga piston (?).
June 12th, 2007 10:08 AM #14
guys, pa update lang ng thread. yung 95 safari (local) ko kasi lakas mabawasan ang oil, but no leaks naman (had all the gaskets/seals checked&replaced already). tapos medyo malakas na ngayon ang usok (black). does this mean i need to have it overhauled? how much would it cost? any reliable yet cheap qc shop you can recommend? TIA
June 12th, 2007 10:56 AM #15
Wulf,
I suggest a dry compression test then wet.
How is the smell and color of your exhaust?
Engine temp?
June 12th, 2007 11:50 AM #16
smells burnt, actually. not too strong but enough to be noticed. had overheating problems a month ago which was solved by replacing the temp valve
June 12th, 2007 02:08 PM #18
yes sir, 2x(!) in the past 5mos. w/ 2 refills n between (used up a 1gallon for both). been using biodiesel also
June 12th, 2007 04:23 PM #19
Compression test talaga ang kailangan.
This way you can verify kung top overhaul or possibly dukot ang solusyon
How is your turbo? Air filter?
Oil can also be pumped through the shaft going to the intercooler and inside the combustion chamber.Last edited by 4JGtootsie; June 12th, 2007 at 04:31 PM.
June 13th, 2007 03:15 AM #20
ah...wala pong turbo ang local version ng Patrol with a TD42 inline 6 diesel engine.
wulf:::gaya ng mga sinabi nila pa compression test mo muna para sigurado ka.
larry:::mukhang ikaw ang may nararamdaman na sakit :D teka...natuluyan na ata na overhaul yan diba? overheat ba kamo?
Suzuki JIMNY [merged threads]
