Results 1 to 10 of 23
- Feb 2006
- 43
March 3rd, 2006 05:19 PM #1Had my valve cover gasket replaced last week (sa Total Baguio). Since nandun na din, had my engine tuned up (palit spark plugs) and changed oil. This afternoon, when I checked my plugs, there was oil sa #1 & #2 plugs (na wala naman before pinapalitan yung cover gasket) and when I took them off, medyo maluwag, so it seems that the service mechanic missed tightening the plugs. So ginawa ko, I took off the plugs and wiped them with a dry cloth. Pati yung kung saan nilalagay plugs, wiped it also. Ano kaya problema? Kase yung nilagay na sealant nung mechanic parang masyadong manipis (as in hindi man lang naubos kalahati ng isang tube of the sealant). Is it the sealant kaya nagkaroon ng oil ang plugs? What preventive things should I do?
Thanks in advance!
March 3rd, 2006 06:33 PM #2
sir baka blow-by yan. observe mo muna. kung nababawasan nang langis, have it check by your trusted mechanic...
March 3rd, 2006 07:26 PM #3
oil on plugs is 95% of the time bad valve cover gasket.
*ian_rex, tinatakot mo naman siya!! blowby is possible pero yun na yung pinaka-scary scenario.
i'm willing to bet mali pagkalagay nung valve cover gasket, either kulang yung silicone, or naipit yung rubber gasket when it was being put back.
March 3rd, 2006 07:34 PM #4
maybe the plugs are not torqued enough. check if it's 1/4 turn after contact or if it conforms to your vehicle's manual.
March 3rd, 2006 09:33 PM #5
wat car sir?
if some of the plugs are wet with oil:
if the plugs are in between camshafts and deep inside the cylinder head (civic, corolla GLi, lancer, etc.), it is the spark plug oil seals.
if it is at the side (corolla xe, carb types, etc.), check the engine compression
if all plugs are wet, check engine compression and check oil level. lose compression and overfill can cause the plugs to get wet with oil...
- Jun 2004
- 1,311
March 3rd, 2006 09:38 PM #6Btw, pag bago yung gasket wag mo lagyan ng sealant except sa specific corners lang ng gasket. The gasket is made to seal itself kung malinis yung surfaces na nilalagyan nya.
Tsikot Member Rank 5
- Nov 2003
- 3,849
March 4th, 2006 10:43 AM #7faulty tightening of the VC gasket will not lead to oil in the plugs. that's caused by either sparkplug oil seals or cylinder o-rings that are worn. or bad valveseals.
THE AUTO SPECIALIST
- Mar 2006
- 607
March 4th, 2006 11:54 AM #8Originally Posted by pomelo
- Jun 2005
- 3,774
March 4th, 2006 12:28 PM #10Originally Posted by speedyfix
Originally Posted by orly_andico
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
