Results 1 to 10 of 10
- Mar 2003
- 10
May 30th, 2003 06:57 AM #1Just want to ask, advisable ba DIY ng engine oil change? what do i need to do and to buy and how much oil do i pour in? what type of oil do u suggest? 2 liter ung engine nung car ko eh. old school ride. thanx alot bros!
- Jan 2003
- 16
May 30th, 2003 08:37 AM #2Originally Posted by budsmokaz
Oldskul d ko kabisado, but for modern autos it needs less than 4Liters to satisfy the oil dip stick. Then punas-punas lang sa konting oil spill sa engine para di kumapit carbon, dusts, etc...KAYA MO IYAN :D . I've been doing kc nagttipid rin ako, kesa sa ibayad mo pa sa iba. :D
- Mar 2003
- 10
May 31st, 2003 02:49 AM #4thanx for the replies. oo nga ung used oil dapat sa gasolinahan.
so i need the following:
- new oil filter
-4 liters of oil
-rags
-pantagal ng oil filter
what's better for an old engine? mineral or synthetic type of oil? is it advisable to use oil additives?
thanx! :D
June 1st, 2003 01:14 AM #5
Most oil filters can be installed and removed without tools.
Ingat lang sa paggamit ng tools. They can sometimes damage the filter or kapag nasobrahan ng higpit, they will leak. Kaya I just use my hands. Sinasabon ko muna ng laundry soap kamay ko para hindi madulas.
- Mar 2003
- 10
June 1st, 2003 06:12 AM #6ok, thanks mga sirs! sa oil filter lang naman ida-drain ung oil dba? atsaka recommended ba maglagay ng additive at gumamit ng engine flush? :D
- 285
June 1st, 2003 09:42 AM #7Originally Posted by budsmokaz
- Apr 2003
- 526
June 1st, 2003 05:26 PM #8look here, if you search sa google for "diy oil change" madami ka pang makikitang may illustrations, tapos pag may question ka pa ask here.
http://www.diynet.com/DIY/article/0,2058,5681,00.html
- Mar 2003
- 10
June 4th, 2003 10:55 PM #9thanx sa info sirs! so di nako gagamit ng engine flush before i-drain at di ko na din dagdagan ng additive no? wat do u guys think?
- Jan 1970
- 164
June 14th, 2003 03:11 PM #10I read somewhere that you should use engine flush only when changing from mineral to synthetic or vice versa so that you eliminate any oil mixing. Aside from that its not really neccessary as long as you go through the process correctly.
suzuki #2... kahit malayo... heh heh.
Car Sales Data (2023)
