I recently noticed a noise somewhat like "tsu..tsu..tsu..." when my pick-up reaches about 30 kph. Para siyang tunog tren na pabilis ng pabilis as I accelerate. The speedometer needle also somewhat vibrates erratically. Above 40 kph speeds ay wala na. The same is below 30 kph. Walang wiggle sa steering wheel. It happens on paved roads. I already had the underchassis/driveshaft parts greased pero nandoon pa rin. Bago na din transmission/differential gear oil at factory specs. Ano kaya ito?
just had my Strada checked at Car World Marilao. Speedometer cable nga ang culprit. Mukhang sakit ito ng mga Strada. They told me they just had 5 Stradas fixed with the same problem and they replaced the speedo cable. Medyo mahal din pala ang speedo cable (1,370 pesos). At least ok na siya. Tinanong ko kung pwede pa-lubricate na lang ulit pero sabi daw di daw magtatagal kaya palit na lang. Sana magtagal siya.
got same problem with the thread starter except that the speedometer needle does not vibrate and the "tsu.. tsu..tsu noise sa front (mahina lang naman) " is heard at 40 kph and above.
-sabay yung noise sa acceleration, pag mabagal, mabagal din umingay and bumibilis din pag mabilis na.
-already checked for any loose wheelnuts and the tires for any 'bukol' (nag bakasali lang...)
-belts kaya??
plano na pa check sa mechanic pero hingi muna ng inputs sa inyo para di naman magoyo ng kesyo kung anu ano kelangang palitan....
thanks
<<<<<I recently noticed a noise somewhat like "tsu..tsu..tsu..." when my pick-up reaches about 30 kph. Para siyang tunog tren na pabilis ng pabilis as I accelerate. The speedometer needle also somewhat vibrates erratically. Above 40 kph speeds ay wala na. The same is below 30 kph. Walang wiggle sa steering wheel. It happens on paved roads. I already had the underchassis/driveshaft parts greased pero nandoon pa rin. Bago na din transmission/differential gear oil at factory specs. Ano kaya ito? - roydok >>>>
