Results 1 to 6 of 6
- Jul 2006
- 48
November 22nd, 2007 11:31 AM #1just last week while driving, i ran over something sa daan. Di ko masyado pinansin. Napansin ko kahapon lang may yupi yung oil pan ko tapos parang may tama rin yung rod dun sa gulong. After nito, parang nagkaroon ng free-play yung manibela tapos parang humina ring yung batak nung sasakyan. Inespect ko yung oil level regularly di naman mabilis magbawas, pero may patak patak lang tuwing umaga. Comments naman po tsikoteers. Thanks
November 22nd, 2007 12:03 PM #2
Possible na tinamaan yung tie rod or lower control arm, or both. Baka hindi na flat yung seal ng oil pan gasket. Have the oil pan replaced pati bagong gasket palagyan mo na rin. Ipacheck mo na rin oil pump usually nasa loob ng oil pan yon, sana hindi tinamaan. Check the rest of the car's undercarriage na rin to be safe.
November 22nd, 2007 12:43 PM #3
Misaligned na nga ang pan mo so have it corrected asap before you lose more oil. Minsan di talaga hindi maiiwasan to run-over some pretty solid stuff, like me one time a block of wood, and even that alone can cause some serious punctures.
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 25th, 2007 06:10 PM #5have it lifter do check what is wrong and where it is leaking from siguro.
- Jul 2006
- 48
November 26th, 2007 09:44 AM #6Salamat po Mbeige, Memphis Raines, Shadow, Speedyfix. Just had it checked last Saturday. For replacement na nga daw yung pan sabi nung mechanic. Yung free play naman, sa chassis tama so baka daw yun suspension bushing and dapat palitan. Anaywayz salamat po na marami sa response. more power to Tsikot.com!
