Results 1 to 10 of 14
September 5th, 2007 11:12 AM #1
hi guys -
i thought my defogger was broken, pero nung tinignan ko, natanggal lang pala yung isang connection. it's a two-pronged metal something stuck sa rear windshield.
i tried putting it back with electrical tape and tested. gumana. kaya lang, natatanggal pa rin. any ideas how to permanently attach it? super glue is out of the question kasi hindi magdidikit yung contact points. i'm thinking of glue gun or silicon.
thanks in advance
September 5th, 2007 02:13 PM #5
hindi kasi pwedeng sa gitna ng contact points lagyan ng adhesive. if that will be the case, there won't be any contact between the two surfaces to close the circuit. kaya nga gumana yung electrical tape and kaya ayaw ko sana gumamit ng super glue.
September 5th, 2007 02:24 PM #6
Take it to a glass shop that specializes in rear windshields. Better have them do it and have them commit the mistake (and replace at their expense if so) than you break your own car and pay out of pocket money to have it replaced.
September 5th, 2007 05:17 PM #7
*mbeige
nyak. sobra na ata yun sir. will try to dab a very small amount of superglue muna. yung hindi ma-coat yung entire surface. hopefully it works
September 5th, 2007 07:39 PM #8
Mahirap talagang i-solder yan ... the copper strip will easily peel-off because of the heat. And once you crease the strip, it'll be hard to straighten it out because it easily rips.
Ordinary glue is no good either, because of its nonconductive property. Even if you don't glue the entire contact surface, there will be little contact pressure ... in other words, the contact point might heat up and burn.
There are repair kits for defoggers, usually made of conductive paint. You can also use repair kits for keyboard foils. These kits usually cost $10 or more. If you can't find one in the Philippines and the cost of having it done professionally is cheaper (against importing a kit), I'd go with mbeige's advice.
Tsikot Member Rank 4
- 2,716
September 5th, 2007 09:23 PM #9got pics?
conductive paint may not apply in your case because it is not a "broken element" problem but rather, if i'm not mistaken, a "loose connection" problem ... in which case you need to fix the loose connector
September 5th, 2007 09:34 PM #10
Looks like TGPH silently edited the article and removed the entry for Velocita Motors/Ferrari.
Car Sales Data (2024)
