Results 11 to 19 of 19
January 30th, 2005 12:23 AM #11
im going to try all the things you suggested. thanks tsikoteers.
ill keep you posted
February 10th, 2005 10:46 PM #14
sorry for the long delay folks..
here's what i did so far:
checked battery connection
checked fuses under the hood and inside the cabin
checked all vacuum hoses
installed my stock hi tension wires
installed my stock spark plugs
changed fuel filter
pagkapalit ko ng fuel filter, nawala ung symptoms ng 3 days. hindi ko nagamit ng halos 3 days din sa weekend. nung ginamit ko uli, pagka start ko, erratic ang idling. tapos namatay na naman buti naman nagstart uli pero di na makuha sa pag rev namamatay pa rin ang ginawa ko steady sa 2000 rpm ng 3 minutes. ayun nag normal.
bad fuel maybe?
a mechanic also told me idle control solenoid daw...
argghhhh
BANNED BANNED BANNED
- 3,790
February 11th, 2005 02:30 AM #15sir, merun akong ganyan dati, my gas tank had alot of kalawang, na binabarahan yung line (tank side). I had to drain and clean my gas tank. Nawala ang problem after that.
February 12th, 2005 04:57 AM #18
palinis mo muna yung fuel tank sa gas station. sayang yung fuel filter kung barado agad.
- Feb 2004
- 65
February 12th, 2005 09:31 PM #19Originally Posted by chris_d
I went with him at LTO's The Link satellite office nung nag-renew sya. We were given a number to...
