Results 1 to 10 of 19
January 29th, 2005 05:46 PM #1
a few days ago papasok ako ng opisina, buti na lang mabagal ang takbo ko. bigla na lang namatay ang makina. syempre restart agad ako. nagstart naman kaagad. pero namamatay uli. kelangan ko pang bombahin ang gas pedal. pagni-rev ko ng ni-rev ayun back to normal na uli.
checked battery & electrical connections. nothing unusual found. ano kaya ito?
hunch ko sa may ignition. o kaya sa carb.
97 honda city; carburetor type; manual transmission
January 29th, 2005 06:35 PM #4
Ganyan din nangyayari sa akin. Namamatayan pag nasa high gears lalo la pag hiwady driving. Palit lang ng fuel filter. Ok na.
Start with the cheapest parts that you can replace right away and work your problem up to the expensive parts.
Tsikot Member Rank 3
- Aug 2003
- 1,251
January 29th, 2005 09:12 PM #6
unahin mo spark plugs... then fuel and air filters... high-tension wire, then fuel pump, then servo kit...
ako pinalitan ko na lahat... tapos ang sira lang pala servo kit... ayun yun mga luma kong parts ayos pa rin nakatambak lang sa garage... kaya gawin mo pagpalit spark plugs pa-check mo servo kit mo pati fuel pump agad...
January 29th, 2005 09:43 PM #7
hmm..nangyari na rin sa amin yan..mamamatayan na ako then had to pump the gas pedal just to keep it going..hula ko dati baka may nakapasok na air dun sa fuel line..so instead of fuel going to the engine mismo, air ang pumasok so nag-choke yung engine.
- Jun 2004
- 1,311
January 29th, 2005 09:50 PM #8I dont think it would be problems with plugs, even if one plug fails the engine would still
run, roughly though. Air filter also would not cause a sudden problem, car would work with a very dirty or no air filter, only gas mileage would be affected.
I would suggest check the fuel filter, it could be that there is inadequate fuel being sent to the engine.
I'm not sure what else to check though...
January 29th, 2005 10:32 PM #9
99.9% barado ang fuel filter mo.
Change mo lang wala ka nang sakit nang ulo.
- Aug 2003
- 1,251
January 29th, 2005 10:55 PM #10Originally Posted by van_wilder
