Results 11 to 20 of 21
- Feb 2007
- 79
September 23rd, 2007 02:13 PM #12may koneksyon kaya ang pagkaputol ng tambutso nya sa pagiging hard starting? ewan ko kung nagkataon lang pero since naputol yun pipe nya nun nagstart ang hard starting. di ko pa napapakabit.
Tsikot Member Rank 4
- Jun 2006
- 2,605
September 23rd, 2007 02:39 PM #13Just reread your 1st post.
Check if your distributor cap and high tension wires are connected the right way. Meaning wire no 1 is connected to spark plug 1. Wire 2 to spark plug 2 and so on. Just in case nagalaw nung nasa body shop. You can also check if your high tension wires are ok using a tester. It should have a max resistance of 25,000 ohms. Kung may isang sira o nasa maling slug, pupugak ang oto. Check mo rin kung nasa tamang timing. Latly, ok ba fuel filter mo?
These things can cause hard starting.
- Feb 2007
- 79
September 23rd, 2007 02:52 PM #14bro ok naman lahat pati mga hi tension wires. fuel filter bagong palit din. isa din sa pinaghihinalaan ko yun pagkaputol ng tambutso. notice ko din na marami nang butas ang muffler.
September 23rd, 2007 03:05 PM #15
- Nov 2006
- 299
September 23rd, 2007 03:13 PM #16kaibigan walang kinalaman ang pagputol ng tambutso ng kotse mo,kahit pa walang tambutso ang kotse aandar pa rin yan,since na nastuck ang kotse mo ng isang buwan maaaring ang problema nya ay sa fuel system,clog fuel lines or something,check mo lang maigi.
- Feb 2007
- 79
September 23rd, 2007 03:13 PM #17tnry ko ulit kanina, nag spray ako ng wd-40 sa paligid ng carb then pinaandar ko. nun umaandar na, inayos ko ang mga hose na naka-connect sa carb. bigla na naman may malakas na kuryente akong naramdaman. natatakot ako kasi baka sumabog ang kotse ko. huhuhu
September 23rd, 2007 03:19 PM #18
kapatid...dalhin mo sa mekaniko yan bago ka mapahamak. wd-40 is highly flammable, and you are using it around an area with electric spark and possible grounding. not to mention the potential bomb that is your gas tank.
experiments are all very well and good if done by someone who knows what he is doing, but don't assume you can read the internet and automatically be able to do these types of things. i hope this doesn't sound harsh - i just want you to be safe
i hope all of us members of tsikot can exercise caution when giving advice and make sure fellow members are taking the proper precautions and are giving the proper warnings, especially to new members
- Nov 2006
- 299
September 23rd, 2007 03:33 PM #19nakalimutan ko kung anong correct word ang tawag dyan,parang arcing yata ang tawag dyan.check mo yung spark plug wire,yung butas na kinakabitan ng spark plug,kung may makita kang parang powder white na guhit eh palitan mo na,parang nagiging bridge kasi siya between spark plug wire at engine.ganoon din sa ditributor cap o sa ignition coil tower kung may crack ito,kahit na maliit na maliit ang crack na ito,icheck mo lang mabuti.
- Feb 2007
- 79
September 23rd, 2007 03:37 PM #20
wala kasi kwenta kahit ano pa tollroad yan eh kung sabay-sabay kayou uuwi. Ang lunas talaga jan...
Traffic!
