Results 11 to 13 of 13
Tsikot Member Rank 5
- Nov 2003
- 3,849
February 24th, 2007 09:35 AM #11an 00 civic will not have an air flow sensor. it is manifold pressure based and hindi naman sya nadudumihan. you'll have to have the tb and iacv cleaned.
kung lumabas yung check engine light sa cluster and the code it throws is for the iacv then medyo madugo yan kasi you will have to have the box repaired also. this is a commong problem with 96-00 civics na matic.
- Feb 2007
- 4
February 27th, 2007 01:20 PM #12Similar problem. Jumpy yung idling. After fast idle at bumaba na to 900rpm, makikita mo sa tach na tumatalon from 800-900 rpm. at madalas lately mag dive anfgrpm pag naka-on ang AC and either stopping the car to a halt or steering a low speed (5-10kph). Namamatay pa minsan, Ano kaya to mga bossing, madadaan ba sa carb/tb cleaning o kailangan patinging ko sa electrical? Which do you suggest i have checked first? btw, 95 lx civic (carb) yung oto.
- Nov 2003
- 3,849
Methinks the Battle of Carthage scene in Russel Crowe's Gladiator (yr. 2000) is a homage to that...
Traffic!
