Results 11 to 20 of 21
Tsikot Member Rank 5
- Nov 2003
- 3,849
September 6th, 2006 09:17 AM #11motul rbf600 brake fluid is excellent. one of the highest boiling points of any commercially available brake fluids.
- Aug 2006
- 337
Tsikot Member Rank 4
- Jun 2006
- 2,605
September 24th, 2006 09:58 AM #13speedyfix & fusion r has a motul 10w-40 change oil promo for P1900 thatl includes labor & the oil filter already.
The oil Speedyfix uses is 10W40. Is it ok to use if my manual recommends 5W30 and says do not use other viscosity. My other option is Havoline energy 5W30. This will cost more. Does havoline Energy really help save gas? What should I go for?
September 24th, 2006 12:31 PM #15
- Jun 2006
- 2,605
September 24th, 2006 09:04 PM #16
- Nov 2003
- 3,849
September 25th, 2006 12:57 AM #17if what is recommended by the engine is 5w30 then try to stick with it. pero also check the temp ratings in the service manual. some manufacturers recommend that viscosity only in colder climates.
it will definitely give you better milage but if you do lots of hard and fast driving it might be better to err on the higher viscosity for the extra amount of protection.
- Mar 2006
- 58
September 25th, 2006 01:24 PM #18
- Nov 2003
- 3,849
September 26th, 2006 12:25 AM #19yup it should be no problem to use it even at that age. we have 10-12 year old cars using that oil in the shop.
we have motul dot 4 and motul rbf600 brake fluid in the shop.
- Mar 2006
- 58
September 26th, 2006 08:50 AM #20
An EV for city driving sounds very good in theory and we've been seriously considering them...
All New Toyota Corolla Cross
