Results 1 to 8 of 8
August 22nd, 2006 11:02 AM #1
hi guys, good day to all...i need your help.yesterday my radio antenna fu__ed up. it doesnt extend anymore, and its motor is constantly running so i have to disconnect it live cable...Is it repairable? if not, how much does a replacement cost? thanks in advance.by the way, the ride is 97 civic.
August 22nd, 2006 11:05 AM #2
Hirschmann (OEM Mercedes) costs about Php 1,500.00 for the whole assembly.
Taiwan brands can go as low as Php 600.00 during carshows (whole assembly also).
OEM Honda will probably be more expensive than either one.
Sometimes it's just the mast or plastic cable that is broken. This can be repaired by your not-so-friendly Banawe freelancer for around Php 500.00/ea.
August 22nd, 2006 11:08 AM #3
Agree, the mast cable usually breaks. Do you still hear the motor running? If so, then just replace the mast.
August 22nd, 2006 11:16 AM #4
yup, usually it's the plastic rack gear that is cut. that's the long plastic cable with gear teeth. if you're on a budget just go to banawe and ask the "mechanics" there to fix it for you. last time i had mine fixed it cost me P400, but the antenna does not extend fully now as some length of the plastic rack was lost.
August 23rd, 2006 09:21 AM #6
Most no-brainer place would be BLADE. Malapit lang kasi SM dito sa amin. hehehe.
August 27th, 2006 03:53 AM #8
since sinabi mo that the motor is working, malamang putol lang yung plastic na mukhang beyblade rod. ganyan din nangyari sa 626 ko at Sentra SS ng cousin ko. pag binaklas mo yan, parang ganito ang makikita mo.
yung color blue yung sinasabi ko.
pinaayos namin yung Sentra SS (B13) ng cousin ko 250petot lang sa banawe.
http://www.kotse.com/forums/index.php?showtopic=12406
this thread from the other board might be helpful.
considering a Ferrari has an average price range of 20-25M. multiply that with 666 units sold then...
Car Sales Data (2024)
