Results 1 to 7 of 7
- Feb 2008
- 3
February 12th, 2008 11:18 PM #1I have a problem regarding dito sa spacegear 2.8 ltr. turbo intercooler na nabili ko from subic. malakas mag smoke belching specially kung papaakyat ang terrain. ano kaya ang problema nito. me ma iidavice ba kayong shop na pwede kong i pa check ang car ko. Thanks
February 13th, 2008 01:11 AM #2
have you already made the basic routine maintenance?
Change Oil, Oil Filter, Fuel Filter etc...
have the nozzles cleaned, check nozzle spray quality and nozzle pressure.
Compression test.
Turbo pressure test. 0.48-0.82 bar
- Sep 2006
- 1,335
February 13th, 2008 02:49 AM #3Check / replace your air filter before you consider bringing your van to a diesel workshop.
If this doesn't correct your problem, we can fix it.
Bye,
Dieseldude
- Feb 2008
- 3
February 13th, 2008 07:47 AM #4bros, thank you for the response. I had just a change oil, replacement of oil fillter & engine oil (mitsubishi oil I bought from a friend working at casa) only last week. Unfortunately kung kelan ako nag change ng oil, nagka problema. Is it caused by the oil I used? Before kasi ang gamit ko castrol, though Ive try to do the maintenance check you told me, baka nga dun ang cause.
bros baka me known shop na affordable kayong alam na pwedeng kong puntahan, paki bigay naman, wala kasi akong makita dito sa bulacan area.
thanks uli.
February 13th, 2008 10:03 PM #5
how about Air Filter?
ano ba ang viscosity nakalagay sa Mitsu oil mo? ano sa Castrol?Last edited by rion; February 13th, 2008 at 10:06 PM.
February 14th, 2008 02:08 AM #6
btw, I don't think the oil brand has got to to with the smoke problem, but I still want to know.
maybe they use some fuel additives while changing it?
- Feb 2008
- 3
February 16th, 2008 12:09 AM #7bro, thanks sa mga advices, id tried chking & replacing the air filter, medyo marumi na pala ung luma. ok na yung car. first time ko kasing magkaroon ng diesel engined car. thanks ulit.
