Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Dec 2003
    i used to have a lancer GLX 91 model, it was a nice car but it had one problem, when i turn it of sometimes, there were instances that it would have that "follow thru"... yung parang sinisinok bago mamatay. but eventually turns off. i tried having it tuned up regulary too...
    now i have a 96 lancer na itlog, same problem, tho less frequent. i tuned it up, replaced spark plugs, fuel and air filter, even change oil and filter... still the same, but it has happened only once since then... hope somebody can help me with that.
    thanks guys!!:worried:
    Dec 2003
    by the way its a lancer EL...
    one possibility is mataas ang idling mo kaya sinisinok bago mamatay makina..
    or it could be a sign of overheating.
    Dec 2003
    high idling? i don't think so, the mechanic already adjusted it... over heating... thanks... just a follow up tho... why?
    thanks guys...
    Does your Lancer EL happen to have the carburator system? Probable cause of bag timing, either to retarded or advanced that gas is still eminent in the chamber when shutting off.
    Nov 2003
    el's are carbs yata if i'm not mistaken. probably nga ito yung problem nya kaya that happens. have it checked lang and make sure tama yung timing mo para ma-avoid mo yung problems na ganyan
    Dec 2003
    yup they are carbs right... pardon the ignorance but how do i chack that, just had my timing checked and it happened again but only once since then... thanks super guys!!!
    It's the angle from your distributor system, which can be slided that cause advance or retarding it. Just be careful though, one wrong slip and that can literally blow you away. High current passes thru that engine part.
    But most shops I've seen nowadays use an infrared beam to check if your timing needs adjustment. Have you check on your spark plugs too? It may need some cleaning, before you have the timing re-adjusted again.
    Dec 2003
    if i'm not mistaken, the mechanic already adjusted the timing, he used the gun that's like a strobe light... since then it has just happened only once...
    had that problem with my singkit (Lancer GLX 91) before. bagong tuneup na, bago plugs pero still the same.
    the problem was traced to a dirty fuel pump.
    this may help.
    Nov 2003
    probably a dirty fuel filter and not a dirty pump
    di kaya sa carb yan?
    baka tumalon ang timing belt ng isang ngipin.
    Dec 2003
    finally found out when my engine gets those hic-ups, i get this whenever i go high hi reving when running like when i go overtaking or go really fast, basta yung high reving...
    what could be the problem?
    FYI lang po, i changed my fuel filter already and new air filters too... hope you guys can help!!! thanks!!!
    Nov 2003
    try and bring your car to a service station or talyer. there is not much that can be done din kung di makita ng mekaniko
    Now, that's the best advice I have read so far. :D
    Aug 2003
    wow.. this is exactly my problem too! except I have an EFI engine. comforting to know it may not be my ECU...
    Dec 2003
    thanks guys... any suggestions for a shop or talyer? was going to marc caltex before pero closed na sila...
    thanks a lot!!!
    johnj2803::: There are numerous shops that can help you deal with your current scenario. Ferdi cousin of afrasay, PM him for details. Or speedyfix, just read under his sig. :D
Mitsu lancer problem
