Results 21 to 22 of 22
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 31st, 2004 12:18 PM #21nope, we won't open the engine yet sa estimate. pero at least when my mechanic gets to see it he will get a better idea of what the problem is in which case mahahanap na namin yung parts you need and outline the steps to solve the problem.
once ok na yung pricing sayo, we will open the engine in which case walang na balikan kasi masisira narin yung ibang gaskets mo which will be replaced din no matter what is done pa to the engine.
June 3rd, 2004 11:17 PM #22
Maverick,
You should do a compression test. This is done by pumping compressed air in each cyl. and getting the pressure reading. This can be done by any shop with the right equipment.
Pump air thru the spark plug hole when on TDC.
You will know where the culprit is when you hear the hissing sound from....
1. Intake (carb or air filter)....leak on intake valve.
2. Exhaust (tambutso)...leak on exhaust valve.
3. Open oil cap......leak on piston rings.
4. Try also to check hissing sound sa radiator....water jacket/gasket
The pressure reading should be the same for all cyl. and should be 85 - 90% of what you put in. Kung may piston na mababa, yun na ang culprit.
By this malalaman mo kung valves, piston rings or gasket....
my 2cent
10 years validity ko yehey , kaya lang sa june pa makukuha physical card :twak2: :rolleyes:
