Results 1 to 16 of 16
    Apr 2005
    Mga bossing,
    Plano ko magpalagay ng turbo sa aking 1995 in line TD42 Nissan Safari. Any feedback, inputs, benefits, advantages or disadvantages? Magkano, more or less, ang budget? Any recommended brand na turbo? Saan pwede bumili? Meron ba second hand?
    this is only my suggestion.....(hope hindi makasama) kung sa province ang punta mo, thats good... but kung here lang sa manila hindi po advisable too traffic, and prone sa accident. just only a suggestion.
    turbo will be good for your engine. infact all diesel vehicles should be turbo charged, it simply makes the engine more efficient. as for the difference on long drives and city driving, your turbo will benifit you both ways.
    as for having a hard time driving in the city, i dont know why it would be, the turbo lag is too light to matter. unless maging evo-safari auto mo.
    May 2004
    Quote Originally Posted by IIE
    Ha? parang mali ata reply mo bro. prone sa accident pag me turbo ang safari?!
    Oknamlarry,
    Tara sama ka subic,shopping tayo ng surplus turbo duon.... or pahanap tayo sa cebu ng suplus turbo kit. Pag brandnew turbo intercooler kit from SAFARI Turbo system from australia,aabot ka ng 150-200k. This was the quote I had nung nag inquire ako nung 1998 pa.Pero maganda sa turbo kit na ito kasama na intercooler and 3inch exhaust kit.
    Check this out.
    "http://www.airpowersystems.com.au/safari/turbo/td42_gq/intercooler.html"
    *note not currently in production daw
    You'll learn quite a bit from them and also know that your TD42 is capable of producing BIG numbers.
    Apr 2005
    Thanks sa mga input nyo.
    Protrek: Kailan tayo punta ng Subic para maghanap ng turbo kit? Where sa Subic pwede makabili? Sayang bakit not in production yn site.
    Nabanggit kasi sa akin na maganda magpalagay ng turbo sa aking TD42 dahil magiging mas reponsive ang makina at maging fuel efficient, among others.
    hehehehe! napansin ko din.... hehehe! sorry po, ang nasa-isip ko turbo (speed) hehehe! anyway good din yun fuel efficient.
    May 2004
    Quote Originally Posted by oknamlarry
    Bro, me trip pa highpeaks ang NPCP this coming Feb. 4. Sama ka ba?
    Meron pa other turbo kits for TD42 meron
    http://www.turboglide.com.au/turboch...td42nissan.htm
    www.turbonetics.com.au/ATS_4wd_td42.htm
    www.axtturbo.com.au/TD42.html
    www.turbofixer.com/nissanturbokit.html
    Pwede i-turbo but don't skimp on the job and the installer, expect to pay around 80K-100K (or more). You can try asking shops with turbo install experience like ERL and Fusion R amongst some. You can use surplus parts (turbine, etc) and have the piping and exhaust manifold fabricated. You'll also have to check on how capable the stock injection pump is to take on the added fuel requirements of boost.
    The OEM TD42 turbo engine has different tranny right?
    Apr 2005
    Protrek,
    Yes, sama ako sa high peaks sa Feb. 4.
    Vinj,
    I am no techie; do not know much about my TD42. Am still in the process of learning the ins and outs of my machine. Thanks for your input. I will continue to ask around regarding the possible installation of a turbo on my rig. Likewise, please continue helping me with what you know.
    Apr 2005
    Protrek,
    Check the sites, very helpful. Dito sa Metro Manila, do you know any shops that sell and/or install turbo kits?
    Vinj,
    Any recommended shop that you know?
    May 2004
    Quote Originally Posted by vinj
    It has the same tranny. But it has the more heavy duty clutchdisk and pressure plate to take the additional 50% hp and torque.
    The tranny could even take the power of a gasoline 5.7 liter V8 as some patrols in australia do when they upgrade for more power.
    http://www.marks4wd.com/nisgqe.html
    But TD42 patrol manual trannys sucks big time in refinement and drivability.
    my GQ has a turbo, it was installed by the previous owner when I bought it inclusive sya plus iyong mga parts na inalis sa kanya pra mainstall ang turbo.
    Like Larry im still learning more about my rig. Pagka me EB kasi ang NPCP laging sablay sa bakasyon ko kaya di ako maksama. I wanted to meet them and Im sure marami akong malalaman about our rigs.
    May 2004
    *oknamlarry
    ikaw ba yung i ime meet namin ni mintoy sa Total gas station sa feb 4? See you bro! Let's check your patrol
    *qman
    Me trail tayo NPCP sa highpeaks,zambales sa feb 4....sana makasama ka this time
    subukan natin lakas ng 150hp 350nm TD42T mo, pa drive ha? inggit ako hehehe
    sayang protrek sablay uli eh hehehe asa middle east ako mid feb pa uwi ko next time na lang.
    honestly i don't feel the boost sa rig ko hehehe maybe because this is the first time to own a GQ mag wa one year palang sya sakin eh and I never get the chance to drive it a lot pag nauwi lang ako di ko pa sya madalas gamitin.
    Sure protrek pag nakasama ko sa EB let everyone drive it and ask for their comments.
    Quote Originally Posted by PROTREK
    OIC. I do think the upgraded clutch is important as this may cause problems later on... i remember the LC80 has been plagued with weak clutches due to the amount of torque the 4.2 TD engine belts on it.
    You can try checking out FusionR on E. Rod (kay AutoXer/Ferman), or ERL Motorworx near Mariposa/ Benitez St. They can give you some pretty good inputs on building a turbo kit for the rig (do's and don'ts, how much boost can a stock TD42 take, budget, etc.) so this can guide you on your project. They may charge more then what other shops may offer but the feedback i used to get from other peeps who had a cheaper turbo job elsewhere then brought it to sila Ferman for re-work said it's worth the additional cost (you might even end up spending more with a cheap job thats miffed).
    Take the time to research and when you find the installer of choice, collect the needed parts before having it installed so you can save on the downtime for your ride.
    You can also send Speedyfix/Migs a PM as he may be able to help out also. ;)
    Just a thought, wouldnt the turbo TD42 make it a bit more harder to drive (modulate?) off-road due to the power surge at a certain RPM, once the turbo kicks in?
    How much right now is the Aussie turbo kit?
    Apr 2005
    vinj,
    Thanks again. Will check out the shops you mentioned. You will help me save time if you could give me their contact numbers, if you know. Am really not aware of the after-effects of a turbo that is why I am asking around.
    Protrek,
    Mismo. Tayo yong mag-meet sa TOTAL sa Feb. 4. See you there.
turbo question
