Results 11 to 12 of 12
February 16th, 2005 01:05 PM #11
as others said floater mechanism is always the culprit but sometimes its also the wiring na naka negative contact sa tank na naka screw may rust na if ur car has the same configuration. it also happened to my lancer boxtype a few years ago so pinabaklas ko they found some rust on the contact and the floater nilinis nila kasi pag hindi ka madalas mag pa full tank the floater gets stuck.but if the mechanic says linisan ang tank wag kang pumayag that will be the start of a big problem..
- Aug 2005
- 121
October 29th, 2005 01:54 AM #12i have the same problem with my benz, one it hits 1/4 bagsak na ang gauge. even the red warning light ng gauge nagloloko e.the only time it goes back to normal is when ipa full tank ko..
New app update for Gcash. It locks the Gcash account to the particular device you are using so you...
National ID Law
