Results 11 to 18 of 18
- Sep 2006
- 47
January 15th, 2007 10:44 AM #11Hmm.. Could it be the long metal bar placed horizontally inside the door panel? I also have this problem and found out only the other day what's the cause. The long metal tube inside the door panel is mounted by a 'rubber-ish' or bubble gum-like material to the outer layer of the door panel. When the door closes, you can clearly see and hear the outer door layer banging to the horizontal bar.
Would anyone know where can we go to have this fixed?
My car by the way is a Civic ES.
- Sep 2004
- 340
January 16th, 2007 07:13 PM #14
Maybe you can sound deaden your doors. The difference between a BMW's door closing and a Corolla's door closing is different talaga. A BMW's door uses more material..sound deadening material. That's why they have a quieter ride than most cars. So sound deadening I think can help. Unless you have loose screws inside ur door that makes that sound u dont want.
January 17th, 2007 08:58 AM #15
Siguro parang silicon sealant lang nakalagay in between. pero medyo malayo ang space ng horizontal bar dun mismo sa door sidings. di dapat sya tatama. dun po sir sa mga nagpipintura kotse alam nila siguro solution dyan.
Minsan kasi yan may maluwag lang sa loob and ussually ay yung holder ng glass windows mismo.
January 17th, 2007 09:32 AM #16
January 17th, 2007 10:28 AM #17
that horizontal bar is the side impact beam. it should not move. ok yun sinabi ni basti08.
January 17th, 2007 10:30 AM #18
re sa windows eh try to replace the channels they could be worn out already.
Monk-owned R53
