Results 1 to 8 of 8
October 19th, 2006 07:45 PM #1
help po, i have a matic honda 94 esi umiinom ng tubig.walang tagas naman kapapalit ng radiator ,checked connections pero ok naman.any ideas mga sir,san po pwedeng magpa ayos nito,may alam po ba kayong magaling sa ESI na shops including electrical?thanks in advance
October 19th, 2006 07:53 PM #2
had a similar problem before,subukan mo pa-check mo yung water pump mo, baka yun ang may sira.
October 19th, 2006 08:15 PM #3
mga magkano water pump sir? aside from water pump ano pa pong other points of failure?
October 19th, 2006 08:41 PM #4
may kia kami before.overnight, water drips from the defective water pump so every morning or before using it, nid ko maglagay ng water hanggang bago ko maipagawa.if im not mistaken, less than 1K lang yung pagkakabili ko sa replacement part nun. di ko lang alam ang price pag honda.
check mo din auto mo habang naka park to see if water is seeping out somewhere.di ako car expert, naka relate lang. antay pa tayo marunong talaga tsikoteers
October 19th, 2006 09:27 PM #6
mga magkano papressure test sir?anonga mga parts pwede ma diagnose ng pressure test?tnx
October 19th, 2006 09:44 PM #7
rate depende sa shop but generally not expensive pwede rin free kung sa kanila paparepair ang problem. applayan lang pressure un system then visual inspection pag hindi nag hold ang pressure; possible sources ng leak; rad hoses, water pump, freeze plugs, radiator,thermostat housing gasket,etc
Tsikot Member Rank 5
- Nov 2003
- 3,849
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
