Results 1 to 10 of 24
- Mar 2004
- 74
October 31st, 2005 01:21 AM #1Na overhaul na radiator ko tapos na replace thermostat tapos na top overhaul na din palit ng cylinder head gasket. pero still nagbbawas pa din ng water pero onti onti na lang. nagtataka ako kc dapat mauubos muna sa reservoir bago ra radiator. pero everytime na bbuksan ko rad cap ko bawas na ang tubig. Ive been tracing water leaks pero wala talaga makita. nag pa pressure test na din ako pero walang lumulabas na tubig.
May mali kaya sa pag palit ng gaskets?
Help naman pls.
- Jun 2005
- 215
October 31st, 2005 02:38 AM #2When they overhaul your engine and change your radiator, they left some area inside with air pocket, its just probably getting filled up. The best way to get, this is to run your vehicle in an incline area with radiator cap remove, continously refill your radiator until it doesn't go down anymore. After another day of driving, check and refill if needed. Hope this help
- Mar 2004
- 74
October 31st, 2005 02:49 AM #3thanks pero parang ang tagal nang ganun almost mag 1 month na. pagmalamig naman napapansin ko wala naman leaks kc kahit cold ang engine pag bukas ko ng cap may hagin pang pressure na llabas knti parang bottle of coke.
- Mar 2004
- 74
November 1st, 2005 12:26 PM #5
Question paj gmbh: nag-ooverheat ba paj mo?? When you open the radiator, walang tubig ba? Also, di naman ba nag-ooverflow yung reservoir? Always add water to the reservoir and keep it between low and full. Observe mo uli.
- Mar 2004
- 74
November 1st, 2005 04:35 PM #6sir estee, hindi po sya nagooverheat. nababawasan sya ng tubig sa radiator mismo. kc araw araw ko sya check tapos bawas na knte. then minsan hinayaan ko d lagyan ng mga 2weeks. pagtingin ko ulit malaki na bawas sa rad pero hindi naubos ung 2big sa reservoir.
- Mar 2004
- 74
November 1st, 2005 04:38 PM #7nga pala sir hindi po nag ooverflow ung reservoir ko. pwede kaya sa water pump? pero wala talaga akong makitang water na lumalabas dun eh even pinapandar ko engine. o pag high revs lumalabas sa water pump?
- Sep 2005
- 16
November 1st, 2005 08:26 PM #8nagpa-compression test and a parameter test ka na? aside from changing the gasket, nagalaw ba ang cylinder head mo? baka may warp, at doon nagpupunta ang tubig, then evaporates.
- Mar 2004
- 74
- Nov 2004
- 141
November 1st, 2005 09:55 PM #10check mo rin radiator cap mo baka sira na or baka local lang. hindi kamo nababawasan ang reservoir mo. pero baka naman due for replacement na talaga water pump mo.
I also prefer silver. hindi halata na madumi na and some imperfections like faded color and slight...
