Results 21 to 30 of 31
November 10th, 2006 12:14 PM #21
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 12th, 2006 12:01 PM #22yup, gave my advice. di na ba bumalik CEL kahapon? have it top overhauled... was following you sa shaw and super dami smoke lumalabas...
November 13th, 2006 07:15 PM #23
November 13th, 2006 07:22 PM #24
^^and it also depends on the markings on the bolt. Some of them can withstand higher torque ratings. Consult your service manual if you can find any, the torque ratings should be listed. Best is to get a Haynes manual, usually nandun yung torque ratings ng head bolts for your car.
November 13th, 2006 09:40 PM #25
Just download the 7G Galant service manual. I'm going to transfer it to the Tech Specs forum in a while.
- Nov 2006
- 72
November 14th, 2006 12:06 PM #26speedyfix,
i have the same problem with my 92 corolla xe. 1 liter of oil every 3 days is lost. i have replaced the gasket and it still loses oil, but lesser quantity na. it is still smoking so i guess oil goes out of the exhaust.
how much would it cost me to get this repaired? i'll probably have it done this coming friday. thanks!
- Nov 2003
- 3,849
November 16th, 2006 12:44 AM #27same thing probably happened... you had the head gasket replaced without the valve seals being checked. baklas ulit head nyan and bili ka bagong head gasket and overhauling kit set.
- Aug 2006
- 70
November 16th, 2006 04:36 PM #28Sir Speedyfix, after reading most of the post on this thread I'm beginning to believe that my engine has the same problem. I'm also losing oil almost a liter every week with average run of 400 km. I feel the engine (22R mounted on RX81) has still a good power if not of the smoke and oil plus (eto pa pala) coolant lose. There's no visible leak in the engine even under the chassis and I can still make 160-170 km on a highway. The previous owner said he had the head replaced. But I doubt they did cause he himself did not see it replaced and the mechanic has that technic of painting the job they did, para daw alam nila kung anong parte ang ginawa nila. Do you think I can solve the problem by having top overhaul and replace the valve seal, valve guide and the valve?
- Nov 2003
- 3,849
- Aug 2006
- 70
November 18th, 2006 08:05 PM #30
