Results 1 to 10 of 31
November 3rd, 2006 12:27 PM #1
Hello!
Nauubos po yung oil nung car ko. Lumalabas ata dun sa Valve Cover? (see attached picture). Valve Cover po ba ito?? Pano po ba ayusin yung leak na yun?? Napansin ko rin nung minsang buksan ko ung cover para mag add ng oil parang may usok sa loob? Normal po ba un?
Thanks!
Note: Picture attached is not the actual picture nung car ko, nag hanap lang po ako ng picture para may maipakita ako kasi mahirap i describe.
November 3rd, 2006 12:37 PM #2
as for the usok, mukhang normal lang yata yan, not sure though.
baka kailangan lang palitan ng Valve Cover Gasket, mura lang yan. Since tatanggalin din naman valve cover mo isabay mo na pa tappet ng valves para isang bukasan na lang.
Also, pa check mo na din yung gasket dun sa may sparkplug, in time nawawala kapit nun, papalitan mo na din kung di na okay.Last edited by artpogi; November 3rd, 2006 at 12:40 PM.
November 3rd, 2006 12:43 PM #3
November 3rd, 2006 12:49 PM #4
assuming your gonna buy an original Mitsubishi Gasket, if you buy the valve cover gasket and the sparkplug gasket, it will probably cost between 1400 to 1800 (note this is "original Mitsubishi gasket"). Ako kasi I don't scrimp when it comes to engine gaskets eh, but that's just me.
Tappet = valve adjustments, madali lang gawin yun, any competent/knowledgeable mechanic can do that.
November 4th, 2006 12:06 AM #5
Hayup ang mahal pala ng OEM gasket niyan. Sa Kia Php120 lang ang original valve cover gasket (para sa Besta). Hindi ko na inalam kung magkano yung replacement. hehehe.
How much oil are you losing? You will not lose that much oil kung purely diyan lang dadaan.
November 4th, 2006 01:10 PM #7
Same thing happened to my friend's nissan B13 engine just this morning, oil leaking at that same spot of the picture, after travelling from meyc bulacan to camiling tarlac. I told him to tighten the philip screws that might be loose...which it was.
November 4th, 2006 01:27 PM #8
try mo muna itighten yung screw sa cover, as teh previous poster said. sa akin kasi ganyan din, i just tighten the screw ang yun okay na sya, no more leak.
mahal talaga gasket ng mitsubishi. try to scout for a good replacement kung hindi makuha sa tightening.
November 4th, 2006 09:54 PM #9
Just make sure tighten it with right torque or esle if you overtighten it the leak will get worst or even damage your valve cover.
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 5th, 2006 12:52 PM #10make sure the leak is not comming from the valvecover washers either.
Latest mileage:
