Results 1 to 8 of 8
    Apr 2008
    hi guys!
    how do i fix my doors? may "lagatok" sound kasi kasi siya everytime i open or close them. it's 96 civic vti po.
    TIA
    spray lubricant on the joints sa door.
    Nov 2007
    baka sira na rubber ng siding ng door mo?
    Nov 2007
    Try greasing the metal part, it's located on the middle when you fully open your doors you will see that there is a part that is higher (that is the one causing the sound), then open and close your door and you will notice the sound gradually getting lesser apply some until the sound is gone...good luck.
    Jul 2005
    Quote Originally Posted by tonyboy View Post
    hi guys!
    TIA
    bro, pareho tayo ng car model, 96 vti din. Also the same problem na meron lagatok pag binuksan yung pinto. I tried applying grease pero ganun parin.
    Jul 2006
    i am not sure kung bearing type sya. if yes. papalitan yung bearing.
    baka kelangan na palitan iyong mga bisagra ng mga pintuan mo bro. kung uneven na lapat ng mga pintuan mo isang indicator na din kasi iyan afaik
    same problem with mine. isa pa, parang hindi nakalapat ang door, konting malubak lang, ang lakas agad ng tunog, pumapasok pa ang water pag nabuhusan sa roof.
    any shop na pwedeng mai-recommend (mandaluyong area) for repair/align the door?
lagatok sa doors
