Water boils * 100 ºC at atmospheric pressure, we add coolant to increase its boiling point na kahit 100 ºC na ay di pa rin magiging gas, but if it reaches pa rin its saturation point ay ganun pa rin, magiging steam 'to and will over flow sa coolant reservior. If you notice ang level ng full ng reserviour ay almost kalahati lang ng tank so that it will compensate the overflowing water from the radiator. Kung nasobra lagay mo matatapon talaga yon.
Kung patay na makina mo, babalik uli yong sobrang tubig from the reservior to radiator because mas mauunang mag cool down ang H2O at the radiator because of its cooling fins.
Pag binuksan mo ang radiator cap ng mainit pa 'to at pressurized it will boil * atmospheric pressure kaya matatapon yong tubig mo sa radiator.
That's explain why dumadami tubig sa reservior and loosing water fr radiator if you open its cap when hot.
Mga Gurus correct me po if i'm wrong.
But it is very possible na clog na ang fins ng radiator mo.
