Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
    #21
    Originally posted by roydok
    If you plan to keep your vehicle longer than the rustproof warranty of your manufacturer then the answer is YES. It does prevent rust formation as an example in our rust-free 10 year old Feroza. Basta have an annual rustproof check or as recommended by the rust-proofing manufacturer.
    If you plan to sell your vehicle before the said warranty expires then it's a NO. Sayang lang pera mo. ;)
    With our experience with Tuff-Kote pinapatungan nila factory rust proof providing increased protection against rust.
    agree ako kay ROYDOK ... pag tatagal sa iyo ng more than 4 years kotse mo eh kelangan mo pa-rust proof pero kung less than 4 years eh wagna.. sayang lang pera... kung sa dad ko eh pina-rust proof namin sa ziebart makati... inabot din ata ng 8K yung revo nya... kasi more 10 years pag magpalit ng sasakyan erpats ko..
    roydok, saan ang tuff kote?
    thanks..
    #22
    Originally posted by chieffy
    kailangan ba talaga ang rustproofing sa bawat car?
    oo kailangan lalo na sa mga areas na bihira mo linisin at makita kung saan may mga nanunuot na alikabok at dumi na maaring mabasa o paglagian ng moisture(underside, behind bumpers, bedliners, door panels-where acid rain drips in...you guys, should have seen the corroded doors of my wife's 1990 AE92)...mas madalas mo gamitin ang sasakyan, mas mataas ang possibilidad ng pagkakaroon ng kalawang...factory rustproofing will not outlast your car's expected life specially if its always exposed to elements(dust, water, air, etc.)
    check out this fuel tank's downpipe (1994 Accord)
    more pics
    this is the front area of my ride(Civic 2000)...rust is starting to form between the joint area of the bumper bracket...guys, how often do you check the paint condition of the panel behind your bumper? your door panel? your underside? nabaha nga pala ako nung Aug 23...i checked the door panels nung August 25...guess what, the door panel factory rustproofing along the drain holes has hardened and starting to crack..sooner or later it will peel off leaving it unprotected from dirt and water...i don't want to experience what happened to my wife's AE92...
    addtl info din ito..
    yung 2000 Revo ng dad ko eh naka super rust proof sa ziebart nung year 2000.. so far ok naman rust proofing... den this year during sa yearly checkup... pinakita namin sa ziebart na meron kalawang sa likod, near the rear bumber behind the backdoor, maliit lang naman at size ng butt ng ballpen...
    then inspect ng advisor sa ziebart at sinundot yung part na meron kalawang... pero di tumagos yung ballpen nya, sabi nya eh di daw covered ng warranty yun dahil paint defect daw at nasa external part ng body.. ang covered ng warranty nila eh pag sa loob ng metal nanggaling yung rust... so pag tumagos daw ballpen nya eh ibig sabihin sa loob nanggaling kalawang at yun ang covered ng lifetime warranty nila..
    whew.. so ngayon alam ko na.. niliha naman ng ziebart yung part na meron kalawang at nilagyan na lang nila ng rust proofing..
    #23
    mga bossing,
    napagusapan dito yung electronic rust proofing device. fyi lang, there is a cheaper, AND MORE EFFECTIVE, alternative to this electronic device.
    buy 2 pieces of pure ZINC bars about 1/2" x 1" x 3" long. have 1 piece soldered to the chasis and another piece soldered to the car body, preferably under the car so hindi kita. the zinc acts as an electrode (anode) and effectively repels salts, acids (including acid rain), sulfur and its sulfides, and even plain old oxygen from atacking the iron in your car chasis and body. it makes tha car chasis and body electrically charged with the same polarity as these chemicals. and since same charges repel, then they go away. ok di ba?
    it works here in the middle of the ocean, it should work there on dry land.
    #24
    AFAIK, yun warranties ng ziebart at tuffkote cover corrosion from inside-out and not metal corrosion due to stone chips or other pointed objects..
    i agree with yebo, zinc prevents rust by oxidizing itself instead of iron.... most german cars are made with galvanized steel panels...these panels won't rust until after the paint is damaged and the zinc corrodes through to the underlying steel.
    yebo, yung ginagamit nyo dyan, di na kaya kailangan ng electical current?
    peeps, saan kaya makakabili ng pure Zinc bars dito? magkano kaya?
    Mar 2003
    #25
    aside from ziebart and tuff coat, has anyone heard of "scrubby coat"? ok ba dito?
    yun kasi yung sticker kung saan pina-rust proof ng previous owner ng car ko.
    Aug 2003
    #26
    hmmm...junk shops? hardware stores? sa HMR baka meron din...problem is, how do u know it's zinc?
    Sa last job ko, me kinalas kami na 19 kopong-kopong na mini computer...ung "hard drive" nya had a base that was made of zinc..or at least they told me it was zinc...sigh....kung maaga mo lang napost by a few years ;).
    btw, ano kaya ung minimum dimensions ng zinc bars?
    #27
    for ZINC bars punta ka sa marine engine supplies, yung mga nagtitinda ng spare parts ng outboard motors. ang outboards kasi ay may zinc bars na naka-weld sa gilid. also, marine vessels have zinc bars welded to its sides below the water line, so this is a normal marine spare part. meron yan sa bandang ongpin, mga marine engine spare parts stores.
    don't buy sa ordinary hardware store at baka ang ibigay sa iyo yung LEAD na pang solder sa roofing. ang lead ay "cathode" (as opposed to anode) and it will in fact attract oxygen to iron/steel and cause rust.
    Nov 2006
    #28
    <<<[/quote]pero if you live in the CAMANAVA area, required po kayo... hehehe
    kami, since we live in Malabon, twice in a year namin pinapabugahan ng Gear oil yung buong pang-ilalim... as in lahat!
    the result::: fresh na fresh parin ang pangilalim at body ng aming mga sasakyan[/quote]>>
    qrius lng po...caloocan kz area
    even may undercoating n nagpapabuga k pa ng gear oil? hndi nanakatangal ng undercoating?
    May 2007
    #29
    magkaiba ba ang rustproofing sa undercoating?
    #30
    Yep. Undercoating is what the name implies. Coating the underside of the vehicle.
    Rustproofing involves drilling holes and forcing the anti rust agent into the hollow cavities of the car (inside the doors, quarter panels, etc.).
