Results 11 to 13 of 13
December 21st, 2007 10:57 PM #11
you buy the parts na kelangan palitan at labor na lang ang bayaran mo mas maliking tipid.. sa banawe ka magpunta mas maraming mura dun.
- Dec 2007
- 13
December 30th, 2007 01:22 AM #12Timing Belt is around 1500 to 2000 lang labor for this is around 1500 to 2000. If your going to change your timing belt might as well include other parts like Crankshaft and Cam shaft oil seal(Php 500 each Orig), Water pump(1500 GMB Brand) and Idler and tensioner bearing(500 to 700 KOYO or NGK). Total for this is about 5 to 6K all in... Dag dag mo na lang Oil Filter, Fuel Filter, Air Filter and Spark plug tapos pa Timing mo.
Clutch namn 1500 to 2000 din labor cost. Parts to replace Clutch Disc Pressure Plate and released bearing.. Mga more or less nasa 6K din yan...
Tsikot Member Rank 5
- Nov 2003
- 3,849
January 1st, 2008 12:29 PM #13when replacing the clutch, sama mo narin yung big crank seal and axle oil seals.
Automatic po Sir
