Results 11 to 20 of 20
THE AUTO SPECIALIST
- Mar 2006
- 607
January 1st, 2011 05:03 AM #11yung jerking , technically called misfire yun . most likely cause nya spark related, you probably need an auto technician not a mechanic to properly handle this trouble.
January 1st, 2011 12:12 PM #12
sir napa linis na po when i had my pms sa speedy. replaced all the spark plugs and the mechanic cleaned the maf. ok nman cya for a while but after almost 2 mos. present nnman yung problem.
tinaasan yung idling (naging 1.4K) para daw wag mamatayan ng makina, a little high but like i posted earlier it was just for a while. took some extra mileage from my regular fc but the problem was solved. after quite some time nag normalize na yung rpm (1K) but the problem cropped up again.
January 1st, 2011 12:15 PM #13
January 1st, 2011 12:20 PM #14
sir ano po yung "obd2"??
saan po pwde magpa read ng mga sensors?
Im at maybunga, pasig right now at ang pinaka malapit po dito na shop ay rapide.
although madami negative feedback nga lang sa rapide but i tried having a radiator flush service from them, mukhang ok nman sila at very accommodating. about 2 weeks pa lang ata silang bukas.
January 1st, 2011 12:21 PM #15
Tol ,sakit na talaga ng Nissan na makina ang Erratic idling. Marami pinanggagalingan Dirty IACV , Throttle body iyong sa akin sinubukan kong mag lagay ng grounding kit nag stable idle niya at maganda performace at lighting niya steady kahit bukas lahat accessory problema kasi iyong lumang stock na grounding kit iyong pinakakapitan naguumido rin iyan at kalawang . Suggestion lang.
- Nov 2009
- 456
January 1st, 2011 10:15 PM #16*Excalibur
You might want to have your ignition coil checked. It can also result in erratic idling when it isn't in good shape.
January 3rd, 2011 12:23 PM #17
January 3rd, 2011 12:28 PM #18
ok nman cya sir wag lang susumpungin.
i noticed nga pala one time sinumpong then namatay makina, after i started it (nsa intersection nka stop yung light) after i switched the engine on biglang naging ok nnman yung andar (pati tunog) nya. may multo????! hahahha :beam:
- Sep 2010
- 23
March 18th, 2011 01:24 PM #19Got the same problem although only occurs when the airconditioning system is on. After revving up, bigla ako mamamatayan minsan sa kalsada, which is very dangerous dahil tumitigas ung break pedal kapag nakapatay makina ko. Btw my car is diff though, it's a civic esi. Idle ko tuloy naka set sa 1.2k kasi pag naka on ac, it would drop 200-400 units, other than that, after revving, bagsak another 200 or 300 or so tapos balik dun sa menos ng 200-400. It's pissing me off, di namin madetect ung problema.
