Results 1 to 7 of 7
    Aug 2003
    there are times that my ride(ee90) would accelerate better, while most of the time me lag talaga. just yesterday while driving myself to MoA, ung papunta, pakiramdam ko mas madali siyang mag accelerate. However, on the way home, back to "normal" na naman siya.
    any hints po on what to check first?
    tune-up muna and check timing
    Quote Originally Posted by t2erns View Post
    +1^ yes timing should be check first!
    Aug 2003
    thanks for the replies
    hmmm...i recently had some repairs done on the engine(replaced some oil seals), and naadjust na ng mechanic ung timing. what other causes could there be?
    Feb 2005
    could your carb need cleaning?
    Aug 2003
    ginagawa ko na rin po to sir...although baka mali ung technique ko. kelangan po bang me umaapak sa gas habang iniisprayan? usually kasi i spray carb cleaner on it while the engine is off at kinoclose-open ko ung throttle valve
    badkuk,
    when spraying your carb with carb cleaner, kailangan naka-on makina, habang ini-spray yung carb, nire-rev mo dapat yung engine by pulling the throttle cable
intermittent acceleration
