The Intercooler fan is turned on by a thermal switch. So, if its hot outside, even if you put the key in the on position, it will still work. but notice sa umaga, before you start, it doesnt do that.
Thanx for the reply. Ang problema nga lang kasi khit na tumakbo na ako for about 70 kms and its really hot outside, when you look inside the hood with the engine still running, the fan still isn't turning.
Its either the fan or the fuse is busted. what i did before was override the thermal switch by shorting the wires. what happened was that my fan was always on.
Thanks. BTW is there a noticeable difference in performance if the fan is turning or not? Just curious coz for as long as I can remember di na talaga umaandar yung fan pgkabili ko ng ride.
Pa check mo sa Rey's electrical or any other competent auto electrical shop. Madalas, upod lang yung carbon contacts nito. Usually nasa P150 lang ang labor. Yung carbon mura din lang. Hindi dapat lalampas sa P500 all in all.
