Results 11 to 19 of 19
- Apr 2007
- 66
June 5th, 2007 12:30 PM #11
June 5th, 2007 12:33 PM #12
actually, engine swap is a good idea. the cost is a little bit lower or even same as an overhaul. the only difference is that, you may put in a bigger displacement or a more powerful engine.
in your case, a 1.3 engine. you can put in a 1.6 or a 2.0 engine from a galant or something.
Zombie
- Aug 2006
- 728
June 5th, 2007 12:53 PM #13happy: carbureted sha eh, dami dagdag gastos nyan pag nag-engine swap sha for a galant engine.
pwede kabit mo na lang jan yung 1.3 ng pizza models.
15k budget? mejo alanganin yan bro, depende kase yan eh, pag binuksan yung engine mo saka lang malalaman kung ano kelangan palitan. kung mabait ang panginoon, valve seals lang yan.
- Apr 2007
- 66
June 5th, 2007 06:03 PM #15
Dalhin mo na lang sa shop na recommended ng ating mga kaibigang tsikoteers and yung mga expert mechanic na ang magdedecide if top overhaul or full overhaul ang kailangan na dyan. To give you a clue naman about sa difference ng dalawa para di ka madaya ;-), usually top overhaul means yung "top end" of the engine lang ang bubuksan and gagalawin, (cylinders, pistons, and valves). Pero if may problem na din for example ang mga crankshaft, camshaft, connecting rods, etc which is located at the "bottom" end of your engine, full or major overhaul na ang kailangan ng engine mo.
The last time na nagpa estimate ako for a full overhaul, Php 35K ang quote sa akin.
HTH
- Apr 2007
- 66
June 5th, 2007 06:42 PM #16ugh 35k wala pa ako sa half. :D pano pag top overhaul lang magkano aabutin?
June 6th, 2007 08:24 AM #17
- May 2007
- 60
June 6th, 2007 11:18 PM #18
June 8th, 2007 10:04 AM #19
Monk-owned R53
