Results 11 to 14 of 14
June 9th, 2005 01:26 PM #11
Have the engine timing checked (it is possible the timing belt setting got placed in wrong).
A tune-up would entail changing the spark plugs, adjusting the ignition timing, and adjusting the valve tappets if needed (this means opening up the head so the mechanic can do it).
On the carb overhaul, there are several shops in Kamuning Rd., QC that can do this (charge around P400-P600 the last time i checked). They open up the carb, clean it, change some parts if necessary, and set it back to spec. I went to "Kamuning Carb Specialists" before and their work was ok.
BTW, it's unlikely your oil is causing this already so leave it alone first and go about checking the other facets mentioned.
- Oct 2004
- 132
June 9th, 2005 01:34 PM #12Heheheh... whats with these second hand cars anyway... tulad nung sa akin... after mo ipaayos un isa... may susulpot na naman na isa... nanibago ata un car mo sa synthetic oil na nilagay mo.
June 9th, 2005 09:30 PM #13
it's a fact of life with used cars that you'll end up replacing part after part after part... i sometimes tire of the routine, but since i'm unwilling to hock a chunk of my monthly income for several years, tiis na muna... :P
- Jun 2005
- 20
June 14th, 2005 01:56 AM #14dude di bagay fully synthetic oil sa mga carb na auto designed un sa mga injected na auto lalo na sa mga 6cyl up. parang sasama tunog engine mo paltan m na kaagad ng ordinary motor oil.
alas, much as we might want to rely on our noses, we may not use our noses to do emissions...
LTO accredited emission testing centers
