Results 1 to 9 of 9
    di ko pa kasi napapagawa. naiirita ako dun sa humuhuni na sound when you open and close the HU. gumagana naman sya maski unti lang ang nakalabas so i am thinking of turning it off muna until mapagawa ko sya.
    i was looking at the fuses underneath the steering wheel, walang fuse na pwedeng tangalin for this.
    san ba sya pwedeng i-disable?
    thanks guys.
    Why not just unplug the power at the motor itself? That is what I did with my power antenna when the "wick" broke.
    putulin mo nalang kaya ang wire sir o kaya eh unplug the antenna cord na nakakabit sa head unit
    depending on the vehicle, mas madali yun sa post ni ghost na just unplug the power of the motor. madalas nasa trunk yan or sa fender pag mga suv.
    gh, where is the motor/power located? sa nissan SS3 ito ha?
    saw it... natatakpan pala ng panel... already disconnected it.... thanks guys.
    On my rig, I used a surplus foglamp switch to cut power to my antenna. So the mast doesn't go up when I'm watching a DVD or just listening from the iPod.
    That way, less likely to get damaged yung antenna especially for taller vehicles where there is a tendency for the antenna to get bent by trees or while inside enclosed parking structures.
    When recepcion is bad, I just press the switch and up goes the antenna.
    Aug 2004
    Quote Originally Posted by 1D4LV View Post
    thanks guys.
    Pull open the cladding inside the trunk (should pop out... the fasteners are plastic.)... you can just unplug the antenna module. (this is assuming trunk-mounted yung power antenna).
    ok na sya mga peeps... natanggal ko na... thanks.
    note: niky, saktong sakto pagkakadescribe mo.
How To Disable Power Antenna
